steel studs/tile
stelly | Posted in General Discussion on March 23, 2006 03:01am
Good Morning,
Can you use steel studs behind cement backer board? (For shower walls) If so what type of screws should I use.
  1. user-124063 | Mar 23, 2006 03:28pm | #1
    Yes, but studs have to be min 20 ga. Durock makes self drilling screws.
    1. stelly | Mar 24, 2006 12:24am | #3
      Thanks,
  2. ruffmike | Mar 23, 2006 03:34pm | #2
    I would also add to make sure you use a good vapor barrier before the cement board. Also make sure your studs are braced, if there is no sheeting on the opposite side, to prevent twisting
                                Mike
    1. stelly | Mar 24, 2006 12:26am | #4
      Thanks, appreciate the information.
