Stove pipe & Copper roof
joeh | Posted in General Discussion on October 13, 2005 04:54am
How?
Simpson Duravent, 6″ pipe that’s about 12″ or better outside. Comes in galvanized & stainless.
How do I detail it where it goes through the copper?
Simpson sells some flashings, all galvanized, no copper or stainless. Local supplier isn’t much help, no experience with copper.
Make my own from copper? They do have something called a storm collar, looks to be just a ring that goes around the pipe and sits above whatever flashing comes up from the roof. I don’t see how this is gonna make a watertight seal, unless there’s some sort of sealant with it.
Help!!
Joe H
Edited 10/12/2005 10:05 pm by JoeH
  1. JohnSprung | Oct 13, 2005 10:23pm | #1
    I think making your own from copper would look better -- it would match the rest of the roof.  It should be pretty simple to sleeve the outside with copper to a point up under whatever cap you have, where it would be sheltered.
    -- J.S.
    1. joeh | Oct 13, 2005 11:12pm | #2
      John, I was thinking of wrapping the pipe itself in copper, but the actual through the roof flashing is my problem. No clue as to how to do it, and no book that shows anything.
      Found a PDF instructions from Simpson, but the actual weather tite details are slim and seem to deal only with a shingled roof.
      They mention using their storm collar over the flashing and sealing it with a unspecifiec mastic. No recommended product.
      I don't want to hack a big hole until I figure out how to proceed. Winter is going to be long and cold is seems.
      Joe H
  2. JohnT8 | Oct 13, 2005 11:27pm | #3
    You might be able to get Grant (greencu, cu, see you) to fabricate something for ya.  Don't know what his rates are, but he's got some purdy work out there.
    He will probably be along eventually.
    "Holding on to anger is like grasping a hot coal with the intent of throwing it at someone else; you are the one getting burned."
    -- Buddha
    1. joeh | Oct 14, 2005 12:11am | #5
      I'm thinking of fabbing up something like what they have in their catalog, but then what? Solder it to the top of the roof?
      Or maybe just a cone with some tabs at the base, solder it right to the roof pan? Probably need to buy the right book that shows how it's done, none of mine address this. Full of pictures and drawing of everything but what I need to do.
      Maybe I don't need a wood stove..........
      Joe H
  3. seeyou | Oct 14, 2005 12:06am | #4
    Here's what you do - buy the proper galvanized flashing and storm collar. Take the flashing apart. Lay it out on sheet copper and trace. Cut out the pieces and assemble. You'll have to solder where the locks were on the original flashing. Solder the flashing to the roof.
    I use Geocel caulk at the storm collar/pipe junction. Wrap the rest of the pipe with copper.
    Birth, school, work, death.....................
    1. joeh | Oct 14, 2005 12:21am | #6
      Way too simple.....
      Off to HD to buy a cheap flashing.
      I have an old Audel's sheetmetal handy book that shows how to lay it out, but buying one for a pattern sounds waaaaaaay easier.
      Thanks, Joe H
      1. seeyou | Oct 14, 2005 01:33am | #7
        Yeah, I can lay one out, but a pattern is quicker. Good luck.Birth, school, work, death.....................
        1. joeh | Oct 14, 2005 02:26am | #8
          Bet the pattern for that handsome Roofer's Hat His Sphericalness was sporting a while back would be close to what I need.
          Joe H
Balancing Density and Privacy in Los Angeles
Four 2200-sq.-ft. detached homes provide flexible open-plan housing on this Los Angeles block.
  • Podcast 548: PRO TALK With Design/Build Operations Manager Jessica Bishop-Smyser
  • Strategies for Venting a Roof Valley
  • Podcast 547: Basement Insulation, Historic Preservation Resources, and Shipping Container ADUs
  • Podcast 547: Members-only Aftershow—Fine Homebuilding House memories
BOOKS, DVDs, & MERCH
Shop the Store
    Buy Now
    Buy Now
  • 2023 Tool Guide
    Buy Now
  • Pretty Good House
    Buy Now
  • Shop the Store
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • Issue 311 - November 2022
    • 7 Steps to a Perfect Exterior Paint Job
    • Options for Smarter Home-Energy Tracking
    • The Fine Homebuilding Interview: James Metoyer
  • Issue 310 - October 2022
    • Choosing a Tile-Leveling System
    • Choosing Between HRVs and ERVs
    • Custom Built-in Cabinets Made Easy
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
