Straightening wavy stored drywall
vigilant1 | Posted in General Discussion on November 27, 2010 08:43am
I’ve been storing about 20 sheets of  fiberglas-faced moisture resistant drywall in my garage for about a year.  I had the stack up on six  4×4’s and now the whole stack is slightly wavy (approx 3/8″ max from “flat” at the worst spots).  Any suggestions?  I won’t need to use these  for another few weeks.
   Ideas I’ve had:
  1) Move the supports so that the “dips” now rest on the supports, let it sit for a few weeks. Wait and hope
  2) Replace the side-to-side supports with ones running the length of the sheets.  Flip and re-stack the pile so that the “dips” are now up.  Wait and hope.
AAnybody fixed wavy drywall before?  Suggestions welcome.
  1. DonCanDo | Nov 27, 2010 10:26pm | #1
    3/8" over what span?
    1. vigilant1 | Nov 27, 2010 11:32pm | #2
      Several "sags"
      There are about 4 "dips" in each sheet, between the places I was supporting them.  So, 3/8" "sags" over approx  2 foot spans.
      1. DonCanDo | Nov 28, 2010 07:41am | #4
        Sounds Bad
        I haven't worked with paperless drywall (and for whatever reason, it's no longer sold around here).  I'm sure the grain runs the long way, just like regular drywall, which means that it's going to be a little harder to straighten.
        3/8" bow over a 2' span in a stack of 20 sheets sounds like a lot.  Are the sheets towards the top of the stack similarly bowed?  It's a little hard to imagine a 3/8" dip in the entire stack.  If not, I would be tempted to dispose of the worst offenders and salvage what you can.  Drywall is not terribly expensive.  Hopefully, you have an easy way of getting rid of a few extra sheets.
        Maybe paperless drywall is more flexible than the regular stuff, I don't know.  I think the best bet is to lay them on a flat surface with the most bowed sheets on the bottom.  If after a couple of weeks, the bow can be taken out with minimal weight (like 2 sheets worth of weight), I would go ahead and use them.  Otherwise, replace them because the extra aggravation you'll experience during taping/spackling will not be worth the price of a few sheets.
        Another option would be to add enough blocking to the framing to take out the bow as you hang the drywall.  Again, this might be more aggravation than it's worth.
  2. calvin | Nov 27, 2010 11:36pm | #3
    Drywall starts out liquid wet.
    They dry it flat, cut it, tape the ends and send it to you.  The moisture released from the concrete floor probably helped with the new shape.  You might be able to reassume its original form with either of your techniques.  Worth a try.
    It'd help if it was brought in and laid flat-weighted on top if necessary.
  3. DanH | Nov 28, 2010 08:02am | #5
    Restack it, but flip every other sheet upside-down.
    1. vigilant1 | Nov 28, 2010 11:04am | #6
      I'll try that
      Thanks, I'll give this a shot and report back.
      Drywall is interesting stuff: All the processing that goes into making a uniform sheet, and all the hassle with packaging and moving a product that weights so much. I marvel that anyone can make money manufacturing it and selling it for 8 bucks per sheet (which includes the retailer's markup). I'd figure it would cost a big chunk of that just to move it from the factory to the store.
      1. DanH | Nov 28, 2010 11:15am | #7
        It's doubly amazing that they can make it in China and ship it here and sell it at that price.  (Kinda gives you an idea what the folks in China are getting paid.)
        Of course, we bought some colored landscape rock -- basically just limestone with some dye on it -- and it turned out that it came from China.  (Thankfully there are no electrical fixtures in the garden to corrode.)
  4. Clewless1 | Nov 29, 2010 08:01am | #8
    I'd do the full sheet under (e.g. plywood) and restack on top. I'd think it would be good to go.
Hole Saws That Are a Cut Above
The Spyder carbide-tipped hole saws cut quickly with a quick-release arbor that makes it easy to remove the core.
  • Podcast 549: Energy Upgrades, Chimney Inspections, and Questions About a Home You Might Buy
  • Podcast 549: Members-only Aftershow—Patios vs. Decks
  • Podcast 548: PRO TALK With Design/Build Operations Manager Jessica Bishop-Smyser
  • Strategies for Venting a Roof Valley
BOOKS, DVDs, & MERCH
Shop the Store
    Buy Now
    Buy Now
  • Pretty Good House
    Buy Now
  • 2023 Tool Guide
    Buy Now
  • Shop the Store
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • Issue 311 - November 2022
    • 7 Steps to a Perfect Exterior Paint Job
    • Options for Smarter Home-Energy Tracking
    • The Fine Homebuilding Interview: James Metoyer
  • Issue 310 - October 2022
    • Choosing a Tile-Leveling System
    • Choosing Between HRVs and ERVs
    • Custom Built-in Cabinets Made Easy
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
