Stripping asphalt adhesive from floor
Waters | Posted in Construction Techniques on June 17, 2006 06:57am
I’m working on a place with original fir floors under linoleum tiles put down with asphalt gum (or that’s what I think it is).
HO wants to get down and save the floor.  We’re down to the asphalt stuff and I remembered a FHB sidebar on a 3M product called “Safest Stripper” used in this exact circumstance–describing an overnight application followed by an easy session with putty knives to to scrape up the softened tar.
I gave the article to him and he went right out and ordered 2 gals of it, schmooed it on left overnight under plastic to keep it wet and guess what?
It didn’t even touch the black stuff!  It’s as gnarly as ever..
Any thoughts?
What is the best/only way to remove this crap from hell?
Thanks,
Pat
  1. djh | Jun 17, 2006 07:05pm | #1
    Waters,
    I had a similar situation some years back. A friend of mine scraped off as much as he could using various scrapers and chisels and then sanded the floors with a drum sander. He went through a lot of sandpaper if I remember correctly. The end result was well worth it the floors were beautiful when finished.
    1. Waters | Jun 17, 2006 07:10pm | #2
      To your recollection, the paper didn't immediately clog?  I too attacked my own floors with 20 grit after the 40 clogged immediately--but mine were only painted--no tar.
      We've got two large rooms to do.
      Definitely worth it whatever we have to do.. pretty well committed to it.  The floors underneath are original, in a home on the local historical registry and are in great shape...except for the 1/8" of hard tar on top of them!
      Sigh...
      Thanks,
      Pat
      1. djh | Jun 17, 2006 07:52pm | #3
        Waters,
        Not sure, my buddy did the job. It's a summer home so he had all winter to do it <g>. I do remember him saying how tedious it was.
  2. BryanSayer | Jun 17, 2006 08:16pm | #4
    Two possibilities to try: cold and heat.
    Cold: Dry ice to make it brittle, then chip it off with a stiff scraper.
    Heat: Heat gun to soften it and scrape up with a scraper. In this case it might be worth using a bunch of cheap plastic scrapers rather than stopping to clean a lot.
    BillHartmann | Jun 17, 2006 08:27pm | #5
    I saw this posted in another forum.
    "We found a "safe" product called Bean-e-doo made by FranMar Chemical. This stuff is amazing when it comes to black mastic. It is soybean based, and has no odor...it is like cooking oil. Pour some onto the floor, spread it around with a broom, wait about 1 hour, and the black mastic turns into liquid. Squeegee into a pile, use oil dry to pick it up, and scrub the floor with a degreaser. We were amazed at the results.
    Our floor is nearly spotless and ready for the next step! Beanedoo was like a magic potion. I highly recommmend it for stubborn black mastic!"
    No quarantees or warnanties.
    1. Waters | Jun 17, 2006 09:29pm | #10
      Thanks Bill,
      I was looking on the franmar site--pretty amazing stuff!
      But--they say not to be used on a wood surface.  Was your floor wood?  Perhaps they just don't want staining?
      We'll be sanding agressively anyway, so perhaps it doesn't matter?
      Thanks again,
      'tarbaby' waters
        BillHartmann | Jun 17, 2006 09:54pm | #11
        I got that off of another site and that is all that I know about it.
  4. sledgehammer | Jun 17, 2006 08:37pm | #6
    Is the floor older then 20 years?
    Did you check for asbestos?
    1. Waters | Jun 17, 2006 09:11pm | #9
      Yes the house is 1920's but HO took out all the old flooring before I came in.
      His deal.
      Thx
      pat
      1. sledgehammer | Jun 18, 2006 01:30am | #12
        The glue also contains asbestos.
        1. Waters | Jun 18, 2006 04:22am | #14
          I'll be sure not to eat it.
          Or sand it.  The 3m "Safest Stripper" seems actually to be softening it considerably after 23hrs...
          We'll see.
          Thx,
          pat
  5. vinniegoombatz | Jun 17, 2006 08:49pm | #7
    the asphalt can be a fire hazard when sanding so keep an extinguisher in the work zone   residue on the sanding belt can light up, so tip machine and snuff it right away      tar has to be completely removed or the polyurrethane will blister from contamination    sharp scraper does inside corners
    1. Waters | Jun 17, 2006 09:09pm | #8
      Fire hazard noted.
      Very good advice.
      Thanks,
      Pat
  6. jrnbj | Jun 18, 2006 03:55am | #13
    'nother poster recently mentioned using D-limonene (leftovers from industrial orange juice production, sort of) with good luck...I posted back looking for more details from him, haven't seen a response...
    I Googled it, & there are industrial supply houses that stock a formulation of it specifically intended for removing mastic, but it's pricey & large amounts...I've been meaning to stop by the local janitorial supply house & see if they have a smaller size, with similar ingrdients, & give it a try....
    1. Waters | Jun 18, 2006 04:23am | #15
      Hmm, thanks!
      Pat
  7. User avater
    MarkH | Jun 18, 2006 02:46pm | #16
    I don't recommend this, but a buddy took up his tar from hel. with gumout carburetor cleaner.  It was very quick acting.  The flamable nature and smell would make me nix the idea.
Fine Homebuilding – April/May 2023, Issue #314
Find online articles on options for countertops, wood-boring bits, ductless heat pumps, tighter miters, fences, and much more.
  • Podcast 548: PRO TALK With Design/Build Operations Manager Jessica Bishop-Smyser
  • Strategies for Venting a Roof Valley
  • Podcast 547: Basement Insulation, Historic Preservation Resources, and Shipping Container ADUs
  • Podcast 547: Members-only Aftershow—Fine Homebuilding House memories
BOOKS, DVDs, & MERCH
Shop the Store
    Buy Now
  • Pretty Good House
    Buy Now
  • 2023 Tool Guide
    Buy Now
    Buy Now
  • Shop the Store
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • Issue 311 - November 2022
    • 7 Steps to a Perfect Exterior Paint Job
    • Options for Smarter Home-Energy Tracking
    • The Fine Homebuilding Interview: James Metoyer
  • Issue 310 - October 2022
    • Choosing a Tile-Leveling System
    • Choosing Between HRVs and ERVs
    • Custom Built-in Cabinets Made Easy
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
