I’ve just moved to land of stucco (and block wall foundations, too). Any suggestions for references on stucco (books, online, anything) and dealing with door and window installations? TIA
There's a constant source of clean water for you to use, and all you have to do is collect it.
Where are you?
You can kind-of think of stucco as a plaster wall, if you're used to plaster. The wall still has wood framing and sheathing and lath, with a thick (7/8 to 1") layer of cement.
Twin Cities, MN area ............. stucco is pretty rare in New England.
