Stucco below grade… will this lead to moisture problems?
MnHomeOwner | Posted in General Discussion on July 27, 2020 06:09pm
House was built in 1994, in Minnesota.  Previous owner had some windows removed and reinstalled in spring 2017, to cure high moisture readings in the walls.  It passed an extensive moisture test before I purchased in fall 2017, and I’m not aware of any moisture problems.
Nearly all of the stucco walls disappear into soil… is that a problem?  A local contractor said there should be a 4″ gap between the bottom of the stucco and the soil.  The guy that built it apparently didn’t think that way, because he left the stucco’s bottom edge pretty sloppy, without flashing, and it’s below grade nearly everywhere.  I dug under the stucco along the north garage wall and took some pictures, which are here:
https://photos.app.goo.gl/aEP7ZaruZSvQ8vqL9
I’d sure appreciate any input.  Extensive grading work would be needed to get a 4″ gap between the bottom of the stucco and the soil.
The Trump Administration Wants to Eliminate the Energy Star Program
The end of this program will likely lead to higher energy bills and fewer business opportunities for the American people.
  • FHB Podcast Segment: Patching Drywall Near a Shower
  • The Unabashed Maximalist
