I pretty sure you can install carpet pad then carpet directly on your subfloor (advantech in my case) but what about tile, laminate or even sheet vinyl. Should you put down 1/4 or 1/2 plywood first?
There are two things to a floor underlayment. If the subfloor is inadequate and intened to be strengthened further by the underlayment, it adds the needed strength. Ceramic tile definitely needs a non flexing substrate to adhere to.
The other concern is smoothing. The grain patterns of a typical cdx and the flakes of the osb or advantec will telegraph through a sheet vinyl flooring or cause excessive wear to a carpet pad backing.
I'm not sure exactly what you mean by laminate. That can refer to many things but if you mean the new engineered flooring products, I would be comfortable using them or most carpet over a 1"advantec.
"The first rule is to keep an untroubled spirit. The second is to look things in the face and know them for what they are." --Marcus Aurelius
on tile we always use cement board as an underlayment, always, same in showers for tile, opposed to hanging the tile on drywall, for vinyl flooring we either lay a 1/4 luann (spelling?) or smooth hardiback, its like cement board but completely smooth and it leaves a nice smooth even surface to lay the vinyl
Edited 11/23/2002 12:38:02 AM ET by CAG
1/2 ac plywood under vinyl to match carpet hight.
