Sub flooring screws
Bodzz | Posted in Construction Techniques on August 15, 2006 03:32am
what kind of screws should I use on sub flooring will grabbers work or are they too brittle
    dieselpig | Aug 15, 2006 03:41am | #1
    Subfloor screws.
    Seriously.
    Grabbers is a brand name of screw isn't it?  I know they make a wood to wood screw as well as SR screws and cement board screws.  Simpson also makes subfloor screws as do Quickdrive and you can probably get a no-name brand as well.
    Google it.
    1. Bodzz | Aug 15, 2006 04:42am | #2
      sorry man I was thinking dry wall screws the grabber brand .... I like the simpson brand but I dont see them around here (Utah) I guess I will just have to ask for them
      1. CAGIV | Aug 15, 2006 05:11am | #3
        drywall screws are a no go
      2. Piffin | Aug 15, 2006 01:53pm | #9
        drywall screws are made for one thing only - drywall! Thus the name.They are weak and brittle - cheaper, which is fine for driving into a paer surface, but put them into hard wood and the shoulder fractures, often without you being aware of it. I've gone to take things apart by backing SR screws out and finding as many asa third of them broken.GRK makes the best strongest screws available AFAIKhttp://www.grkfasteners.com/index.asp
    2. DanH | Aug 15, 2006 05:33am | #4
      What does a subfloor screw look like? I've never seen one (that I know of).
      1. Bodzz | Aug 15, 2006 06:15am | #5
        well I am thinking now they are just wood screws plain wood screws I am trying to get this down I am going to build my next house and I want to do it all.... but do it right I have seen a lot of homes being built that look bad ( workmanship ) not all.. but more then there should be...like what side should the hurricane brackets be on the inside or out .. if you look in the simpson strong tie book they show them on the out side of the wall I have seen them both ways and on one house they were half of them were outside the rest were inside ... we are talking the lower cost houses like 150 to 200,000 dollars but still it should not matter what the cost is ..I am not hacking on anyone but have just seen some stuff as I have been looking around that really surprises me but anyway any help would be most appreciated
          JonBlakemore | Aug 15, 2006 06:19am | #6
          Simpson H2 & H2.5's should be installed on the outside if you're using trusses. They need to be fastened to the top chord of the truss not the bottom chord.
          1. Stilletto | Aug 15, 2006 01:15pm | #8
            Depending on heel height,   you can't put 2.5's on the top chord.
    xxPaulCPxx | Aug 15, 2006 10:19am | #7
    Senco makes a really good screw, and is widely available at the big boxes.
    Also a CRX fanatic!
Electric House Made With Cross-Laminated Timber
Integrating cross-laminated timber, wood-fiber insulation, panelized construction, and a solar-tile roof for Passive-House performance.
Get an overview of the process of creating a traditional-style fireplace that burns well and meets current building codes from experienced mason Mike Mehaffey.
  • Podcast 569: Bath Fan Installs, Sunroom Trim, and Basement Control Layers
  • Podcast 569: Members-only Aftershow — Rob Yagid’s Addition
  • Fine Homebuilding – July 2023, Issue #316
  • Fine Homebuilding Issue #316 Online Highlights
BOOKS, DVDs, & MERCH
Shop the Store
  • 2023 Tool Guide
    Buy Now
    Buy Now
  • Pretty Good House
    Buy Now
    Buy Now
  • Shop the Store
  • Issue 316 - July
    • Timber-Framed Solar Canopies
    • Build a Transom Above a Stock Door
    • Understanding Toilet Design and Efficiency
  • Issue 315 - June 2023
    • How to Craft a Copper Roof
    • 5 Lessons from Building in a Cold Climate
    • The Advantages of Cellular PVC Siding
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
