Hello all,still working on my new house and I was wondering if I can use 1/2″ cdx sheathing under 3/4″ hardwood flooring?
There is already a 3/4″ t&g plywood subfloor there,but I want to beef it up a bit ,plus the transition into a tile floor would be better.My tile book says not to use it for tile because its not smooth enough for tile so I was wondering if that was the same for hardwood? I cant see it being a problem.
( I all ready have the sheathing ,it was left over)
Thanks Greg
Lead,Follow,or Get the Hell Out of the Way!
Hello Greg:
I've used CDX sheathing under hardwood many times without problem. I don't do floors for a living though so my advice may be worth what it costs. One recommendation would be to fill any voids in the surface of the sheathing ("C" surface should be OK as is, but if there are missed knot holes in the surface ply, might as well fill them). Also, I would use subfloor adhesive between the 3/4" and 1/2" sheets to avoid potential for squeak at that interface.
Best of luck
Thanks for the reply.I cant see it beeing a problem but I just wanted to be sure before I go and glue&screw about 30 sheets.
I figured somebody here has done it before.I needed to get that little extra feed back.
Thanks GregLead,Follow,or Get the Hell Out of the Way!
Wow, 30 sheets, almost 1000'sq. Hope you have help or maybe, like me, just need to be patient with daily progress tackling it solo. Take your time, think ahead, and that floor will be beautiful. Send pics when done. Like to see it.
On the thinking ahead score, I remember the first time I did a floor with border. Long narrow hallway to a staircase, which widened at a 45 angle at the staircase so the hallway went around the side of the staircase. Getting started, I painstakingly laid out the main hallway so the border would be exactly equal away from the wall at each side, and left figuring out the widening part to when I got there. Well when I got there it was then that I realized that the boards don't magically change width to keep a border equidistant from the walls as the hall widened. As luck would have it, the hallway jusst happened to have the widths so that both parts, and the width of the staircase, worked out to even multiples of 2 1/4" (width of the flooring I put in) so it worked out perfectly -- odds of that happening seem to me to be pretty low. I just about wet my pants when I realized how lucky I was and how close a call I had to disaster. Only way to learn I guess.
Best.
Edited 2/25/2006 2:19 pm ET by philarenewal
I got a couple of firefighter buddys I'll get to help on this one.
Glue & screw the second layer, then use 2" flooring nails, not 1-1/2".
Thanks Eddie :
I'm not sure if I'going to get the chance to install the hardwood although I would like to give it a shot(the dw )has other ideas.I might be able to convince her to let me do the master bedroomOnce she sees what the bill is going to be.
I have already done way too much on this house by my self and the wife wants me to just get it finished
If I dont do the job I'll let the installers know to put in 2" nails(good idea)
CDX is fine.
Shoulda been fine for the tile as well.
Only time I spend the money on UL ply is when its being carpeted.
J. D. Reynolds
Home Improvements
I didnt think it would matter ,but wanted to be sure.In john bridges tile book he dosent recomend the cdx for tile because of the knots but I think he's splitting hairs on that one.My tile guy says the thinset adhears better to the cdx.
Thanks Greg
Edited 2/26/2006 11:43 am ET by greggo
