Supplementary heat in a bath
ceb | Posted in Construction Techniques on June 16, 2006 10:42am
Have a small powder room that I’m redoing. Room is always cold as it has two exterior walls and is at the far end of the duct run. Ideally I’d rip all the walls out & add better insulation, but it’s a tight space already. instead I want to add a supplementary baseboard electric heater. Can’t use a toekick heater as there is no cabinet to tuck it under. Question is, can I install this behind the toilet? Two issues come to mind –  water and electricity are rarely a good combination, and the effect of the heat on the wax ring. Don’t know the answer to the first question, but planned on using one of those o-ring gaskets to prevent hte latter problem.
any advice?
Carlos
Edited 6/16/2006 4:12 pm ET by ceb
    zak | Jun 17, 2006 12:35am | #1
    It seems to me that you could still improve the insulation on those two exterior walls, if you want to do that- ridgid foam will be much better than fiberglass, if that's what's in there.
    A radiant heating mat could go on the floor- it adds a lot of comfort, all though it doesn't heat up the room like a baseboard does.
    zak
    "so it goes"
  2. WayneL5 | Jun 17, 2006 01:41am | #2
    Splashing from use of the toilet will corrode the heater in no time and it will be an ugly rusted mess.
    I second the recommendations of the first responder.  The insulation in your walls may have been poorly installed or missing in spots, so even if you add no thickness you may very well be able to improve it.  Secondly, even ½" or 1" of foam board will help a lot.  I'd recommend unfaced fiberglass batts carefully installed with foam board over everything.
    The in floor heat won't add many BTU's to the space, but with better insulation it may be just enough.  And warm floors may add more apparent comfort than just the increase in air temperature alone.
    If your window is really bad it may be part of your problem, too.
    Another alternative is a flat panel radiant heater that you mount on the wall.
    BillHartmann | Jun 17, 2006 01:48am | #3
    In addition to the infloor radiant heat there are also in wall heaters that fit in a stud space if you have an internal wall.
    Also vent fans with heaters.
    And "cove" ceiling radiant heaters.
    1. ceb | Jun 17, 2006 06:32am | #4
      Thanks, hadn't thought of the corrosion issue. You can see I wasn't very happy with my options. May have to reconsider to make space for a toekick heater, although I've never liked them much. As to more insulation, I was hoping to avoid tearing out the existing drywall and avoid mission creep.
      Carlos
        tfarwell | Jun 17, 2006 07:23am | #5
        Another option might be an infrared heat lamp in the ceiling. You would not have to worry about the wall or floor space.
        For the most part, they are in older bathrooms, but its an easy install and quickly heat up the space. There are newer units out there that look pretty good. http://www.elights.com/nutbulheat.html
        As for the insulation, I would also consider taking the sheetrock down and installing rigid foam. You can get up to R-5 per inch, and take the time to make sure everything is air-sealed.
Kimberley Robles, Decorative Concrete
In this interview, Kimberley talks about the importance of proper training, current concrete trends in the Bay Area, and the history of racist housing policy in San Francisco.
Get an overview of the process of creating a traditional-style fireplace that burns well and meets current building codes from experienced mason Mike Mehaffey.
  • Podcast 549: Energy Upgrades, Chimney Inspections, and Questions About a Home You Might Buy
  • Podcast 549: Members-only Aftershow—Patios vs. Decks
  • Podcast 548: PRO TALK With Design/Build Operations Manager Jessica Bishop-Smyser
  • Strategies for Venting a Roof Valley
BOOKS, DVDs, & MERCH
Shop the Store
  • 2023 Tool Guide
    Buy Now
    Buy Now
    Buy Now
  • Pretty Good House
    Buy Now
  • Shop the Store
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • Issue 311 - November 2022
    • 7 Steps to a Perfect Exterior Paint Job
    • Options for Smarter Home-Energy Tracking
    • The Fine Homebuilding Interview: James Metoyer
  • Issue 310 - October 2022
    • Choosing a Tile-Leveling System
    • Choosing Between HRVs and ERVs
    • Custom Built-in Cabinets Made Easy
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
