In every issue you'll find...
  • Expert insights on techniques and principles
  • Unbiased tool reviews
  • Step-by-step details to master the job
  • Field-tested advice and know-how
Subscribe Now!
support ridge beam with chimney?
User avatar
mmoogie | Posted in Construction Techniques on September 14, 2009 06:06am
I’m in a design situation where I want to put a structural ridge beam into a space that has a masonry chimney running up the center of one gable end inside the building envelope.
I’ve seen recent (less than 30-yr-old) construction where a glue-lam was resting right on a pocket in the masonry, but I doubt that would fly today. How can I deal with this? Is there some fire-safe way to pocket a beam into a chimney mass?
Steve
  1. fingersandtoes | Sep 14, 2009 07:01am | #1
    You might want to try an advanced search as I remember this coming up about a year ago. As I remember there was a minimum amount of masonry separation required between the beam and flue, but it was commonly done.
  2. Piffin | Sep 14, 2009 01:00pm | #2
    I doubt that you could do it to an existing chimney safely or structurally, but with a new one with proper design ( from footer up to consider the load path and total point load ) you can do it by leaving 12" of masonry between flue ( fire path) and the wood.
      mmoogie | Sep 14, 2009 01:58pm | #3
      It would all be new.
How to Install Exterior Laminate PVC Siding
In this video, learn how hidden fasteners make for a seamless feature wall.
  • Podcast 484: PRO TALK With Color Consultant Paula Gaull
  • Using Liquid Flash at a Wall-to-Foundation Connection
  • Forming Foundation Walls
  • Track Lighting for Functional Ambiance in Busy Spaces
BOOKS, DVDs, & MERCH
Shop the Store
  • Pretty Good House
    Buy Now
    Buy Now
  • Outdoor Projects
    Buy Now
  • 2021 Fine Homebuilding Archive
    Buy Now
  • Shop the Store
  • Issue 309 - Aug/Sept
    • 10 Steps to Install Crown Molding on Cabinets
    • How to Get Sturdy Walls Without OSB
    • Choosing the Right Construction Tape for the Job
  • Issue 308 - July 2022
    • Pretty Good House Book Excerpt: Copper Farmhouse
    • 10 Dos and Don'ts for Electric In-Floor Heat
    • A Sturdy Rail for Outdoor Stairs
  • Issue 307 - June 2022
    • How to Raise a Post-Frame Home
    • Trimming Deck Stairs
    • Evolving an Energy-Efficient Envelope
  • Issue 306 - April/May 2022
    • Framing Stairs to an Out-of-Level Landing
    • Building a Zero-Energy Home for Less
    • Good-Looking and Long-Lasting Traditional Gutters
  • Issue 305 - Feb/March 2022
    • The Steady Surge in Residential Solar
    • The Fine Homebuilding Interview: William B. Rose
    • How Good Is Your Air Barrier?
  • twitter
Taunton Network
  • Copyright
  • Do not sell my information
© 2022 The Taunton Press, Inc. All rights reserved.
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
