tankless water heater
wideeye | Posted in General Discussion on February 23, 2007 11:17am
Anybody have any experience with a tankless water heater? Is this the same thing as on demand hot water? What are the advantages and disadvantages compared to regular hot water tanks? Thanks and have a good one.
  1. danski0224 | Feb 24, 2007 01:25am | #1
    It works well, if it is used within the specs of the unit.
    You need to pay attention to the flow rate (GPM) and the temperature rise. Most tub fixtures will flow more water than the unit can heat for a "hot" bath- unless you restrict the tub spigot or buy a bigger GPM model. Things like showers and sink faucets are not a problem within the flow specs.
    You can get fancy with them and use it as a small boiler feeding an indirect fired water heater and storage tank.
    You also need to ensure that the existing flue is propely sized if it is to be vented with your other appliances, otherwise you need to use the manufacturers venting kit.
    Lack of combustion air could be a serious problem- medium sized gas fired units are 190+k btu compared to the typical 40k btu water heater. Manufacturers tankless flue kits usually include provisions for a combustion air intake pipe.
    Gas piping also needs to be properly sized. A 1/2" drop at the end of the run isn't gonna cut it for a 190k btu tankless heater.
    If your hot water usage habits change with the limitless hot water, you will not see any savings on the utility bills... the bill will go up :)
    Manufacturer websites usually have install suggestions, piping diagrams, etc.
Solar Shingles in Austin
A Tesla roof powers this five-bedroom Texas home and then transfers extra energy to the power grid.
  • Podcast 549: Energy Upgrades, Chimney Inspections, and Questions About a Home You Might Buy
  • Podcast 549: Members-only Aftershow—Patios vs. Decks
  • Podcast 548: PRO TALK With Design/Build Operations Manager Jessica Bishop-Smyser
  • Strategies for Venting a Roof Valley
BOOKS, DVDs, & MERCH
Shop the Store
    Buy Now
  • Pretty Good House
    Buy Now
    Buy Now
  • 2023 Tool Guide
    Buy Now
  • Shop the Store
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • Issue 311 - November 2022
    • 7 Steps to a Perfect Exterior Paint Job
    • Options for Smarter Home-Energy Tracking
    • The Fine Homebuilding Interview: James Metoyer
  • Issue 310 - October 2022
    • Choosing a Tile-Leveling System
    • Choosing Between HRVs and ERVs
    • Custom Built-in Cabinets Made Easy
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
