tankless water heaters
BIGJIM05 | Posted in General Discussion on March 22, 2006 09:40am
Hello again Can anyone tell me what would be a good tankless hot water heater? What is the pros and cons from replacing an old gas hot water tank for a two flat to this type of unit?
Is install difficult and if so do I use a plumber or and electrician since what I heard from friends they are electric?
  1. Bellcamp | Mar 22, 2006 11:47pm | #1
    Be careful, a tankless water heater uses ALOT of eletriticy or gas depending on which you buy. You may not even have a big enough electric service to handle the additional load. Don't know about the gas line but would check with someone before purchasing one. I couldn't recommend a tankless water heater.
    1. BIGJIM05 | Mar 23, 2006 03:12am | #3
      Ok so can you tell me your opinion on the best gas hot water heater that is a 40 gallon tank with the best effenciency rate/recovery?  Is there a certain brand that is better than others?
      Thanks again
      1. ruffmike | Mar 23, 2006 03:19am | #4
        Do some searches in the heating- insulation section. lots of threads about tankless etc.                            Mike
      2. Bellcamp | Mar 23, 2006 03:51am | #5
        No not really, Why are you not considering electric water heater, they are much cheaper to purchase and with the price of gas they can be as cheap to run depending on your electric rate. They have improve the electrics so their recovery rate is much better than it used to be.
          Sailfish | Mar 23, 2006 05:26pm | #11
          One could also factor in the environment went choosing gas over electric. As well as storage space for a tankless over a tank.
          I have recently purchased a Rinnai exterior tankless ng. looking forward to using it.-----------------------------------------------------------------------------
          WWPD
      3. plumbbill | Mar 23, 2006 03:55am | #6
        Best in efficiency or reliability?
        A O Smith, Rheem Rude, & BradfordWhite are the 3 leaders & been around a long time with great reputations.
        Prestige claims to have a 95% efficiency rating --- I'm not sure about their longevity & track record though."There are about 550000000 firearms in worldwide circulation. That's one firearm for every twelve people on the planet. The only question is...........How do we arm the other eleven?" Yuri Orlov<!----><!----><!---->
  2. paul42 | Mar 22, 2006 11:52pm | #2
    Rinnai seems to have a very good reputation for the tankless heaters.
    Tankless heaters come in gas, propane, and electric models.
    I really prefer to do things myself, but these are complex and expensive enough to convince me to hire an expert.  Find somebody that has experience.
    I really prefer the gas or propane models over the electric.  Both are likely to need larger gas line and vent than your tank style heater.
    The electric models have a tendency to make the lights dim everytime they kick in, unless your house is wired better than most.  The pull a LOT of current.
    1. paul42 | Mar 23, 2006 07:02pm | #12
      For my own use, I'm seriously looking at a heat pump water heater.
      In my area with my life style, I need at least some air conditioning and or dehumidification about 10 months out of the year anyway.
  3. cliffy | Mar 23, 2006 04:03am | #7
    Where I used to work we had two of the Bosch tankless heaters and they were awesome.  If you plan on using only one item at a time that is.  If you want to run the dishwasher and have a shower at the same time, get a tank.
    Have a good day
    Cliffy
  4. user-126003 | Mar 23, 2006 06:24am | #8
    A friend of mine has one , water never gets hot enough and it takes awhile to get there.
  5. user-75913 | Mar 23, 2006 04:12pm | #9
    http://www.jlconline.com/cgi-bin/jlconline.storefront/4422ac9a0037c75f27177f00000105b0/UserTemplate/82?s=4422ac9a0037c75f27177f00000105b0&c=41a20082b6184377041c4fd97905abde&p=1
    JLC did an article on tankless last month
    DDay | Mar 23, 2006 05:13pm | #10
    Journal of light construction had a pretty good article on them last month.
    http://www.jlconline.com/cgi-bin/jlconline.storefront/4422ba7c0012a61c27177f00000105a7/UserTemplate/82?s=4422ba7c0012a61c27177f00000105a7&c=41a20082b6184377041c4fd97905abde&p=1
Eichlers Get an Upgrade
Performance improvements for the prized homes of an influential developer who wanted us all to be able to own one.
