taping metal corners
moonmlns | Posted in Construction Techniques on July 29, 2006 02:09am
I’ve always overlapped tape onto my metal corners. But, in the area i’ve moved into that doesn’t seem to be the norm. I was just wondering if going without taping corner metal is common in other areas as well. thanks
    Huck | Jul 29, 2006 02:42am | #1
    Yes, it is.  The little holes are for the mud to lock into the cornerbead, so tape is redundant.  I've seen it both ways, but the majority of sheetrock contractors here don't tape metal cornerbead.
    "...never charged nothing for his preaching, and it was worth it, too" - Mark Twain
  2. Mooney | Jul 29, 2006 03:02am | #2
    Well it mostly isnt done but if you are doing it , its a good idea.
    Heres why;
    Un taped corners can stay wet for days preventing finishing .
    Taped corners will be dry in the morning after afternoon taping the the day before .
    Sometimes if the corner is crimped it will show a small crack unless its nailed off properly. So in pre mature cracking tape is good insurance .
    It saves mud and is less costly in material overall .
    On a problem deep corner its the cats meow to deep filling . It will also hold a greater amount of mud in place .
    On high standing metal the tape will camoflouge shiners.
    I tape all metal sides .
    Tim
    1. FLA Mike | Jul 30, 2006 04:38pm | #4
      This is why I love this site.  I never thought of taping outside corners, but this makes total sense!  In fact it sounds dumb NOT to do it.
    2. blue_eyed_devil | Jul 30, 2006 05:08pm | #5
      Thanks for the tip Tim! I will heretofore tape the corners!
      blue
    3. moonmlns | Jul 31, 2006 12:06am | #10
      This has been interesting responces. Mooney, you have the same list that i came up with recently. I've been doing remodel work for over 15 years in Alaska, Oregon and now Washington. the area I'm in now is very rual(north eastern partof the state). Every repair of a corner that i have done has been a corner without tape. In the home repairs i'v done i've never had to repair a corner that was taped,with one exception and that house had 2 pluse inches of setteling. Thanks to everyone that gave input. Jack
    trout | Jul 29, 2006 04:20am | #3
    It's seen mostly on commercial and better residential jobs, because it's more durable.
    BarryE | Jul 30, 2006 05:09pm | #6
    I always taped my metal beads,for most of the reasons that Mooney mentioned, not redundant at all. Corners don't crack this way.
    Not to many drywallers around here do it, although a sub I use sometimes runs fiberglass tape down his beads, I still prefer paper tape
    Then I found No Coat corners and haven't looked back. Still use USG's paper bead quite a bit, both save time
    Barry E-Remodeler
      Huck | Jul 30, 2006 06:30pm | #7
      I switched to tape-on metal corners awhile back, and much prefer them to nail-on.  I get mud behind the bead, for a more solid corner, and there are no defects caused by the nailing distending the metal.  Mud here is cheap enough that a little more mud is not an economic issue.  Labor is the big cost with drywall finishing here, and I find the tape-on corners go faster than nail-on.
      Haven't tried No Coat corners, but I've seen them advertised.  To be honest,  I'm not sure I grasp the concept.  Could you elaborate a little?  thanks!
      Edited 7/30/2006 11:34 am by Huck
        BarryE | Jul 30, 2006 08:40pm | #8
        They used to have a clip of it in use, I have to leaveright now but I'll see if I can find it later
        Barry E-Remodeler
  5. WayneL5 | Jul 30, 2006 09:08pm | #9
    A drywall contractor doing work at our plant used metal corner bead attached with adhesive.  It looked like red contact cement that was spray applied.  I don't know if they sprayed it on or if it came that way.  They said they much preferred that to nailing or screwing.
    1. Shep | Jul 31, 2006 05:00am | #11
      I've used the 3M high strength spray adhesive to glue on corner bead. I usually spray both sides, set it in place, and use a corner crimper to drive it home.
      I started doing it with metal studs, and liked the results so much I do it with all the corner bead I set.
      Which isn't all that much anymore.
        Potwin1885 | Aug 03, 2006 02:27am | #12
        I also use 3M Hi-strength 90 to attach corner bead.  I then spray down both side of the bead and put on fiberglass tape.  Mud as usual.  No nails, no crimps.  No cracks!
        Mark
        1. Shep | Aug 03, 2006 03:57am | #13
          I haven't done the fiberglass tape on top of the corner bead.
          I'll try it next time .
          1. MisterT | Aug 04, 2006 01:23pm | #14
            DW guy in ME used to set his corners in Durabond 90
            you could bounce truck off of them...
            taping is one of those things I thought would be a good Idea...
            but all the boss types said it was not ($$$ talikng)
            I will be doing it on ay MY jobs!!!I have no comment...
Flashing a Window Using ZIP Tape
Travis and Joe walk through the step-by-step process of prepping, caulking, and flashing a window using stretch tape and flashing tape from ZIP System.
  • Use a Press Tool for Plumbing Connections
  • Remodeling Around Electrical Panels
  • Podcast 567: Soundproofing, Garage Doors, and Rotted Balconies
  • Podcast 567: Members-only Aftershow — Andrew Zoellner’s House
BOOKS, DVDs, & MERCH
Shop the Store
    Buy Now
  • 2023 Tool Guide
    Buy Now
  • Pretty Good House
    Buy Now
    Buy Now
  • Shop the Store
  • Issue 315 - June 2023
    • How to Craft a Copper Roof
    • 5 Lessons from Building in a Cold Climate
    • The Advantages of Cellular PVC Siding
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • Issue 311 - November 2022
    • 7 Steps to a Perfect Exterior Paint Job
    • Options for Smarter Home-Energy Tracking
    • The Fine Homebuilding Interview: James Metoyer
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
