Testing rechargeable batteries
JonBlakemore | Posted in General Discussion on November 25, 2008 08:06am
I use a slew or NiMH rechargeable AA batteries. For convenience, I try to get all of my electronic devices on AA.
Over the past several months, I’ve been having some issues with *fresh* batteries (meaning they just came off of a 12-24 hour charge cycle) not having enough juice to get the job done.
I’m wondering if I can use a multimeter to test the batteries? I’m not trying to see if they have a charge left in them, rather I’m trying to determine how much of a charge they will take.
I just took a sample of 7 batteries, reading the amps and the voltage. The voltage, which is supposed to be 1.2v according to the info printed on the batteries, is showing between 1.39v and 1.53v. The amperage is much different. The range I have is between 540 mAH and 1395 mAH. The listed mAH is between 2000mAH and 2650mAH.
Are all of my batteries shot? Is there a range of volts or amps that I should be looking for, or am I not even headed in the right direction?
Jon Blakemore
RappahannockINC.com
Fredericksburg, VA
  1. FastEddie | Nov 25, 2008 09:23pm | #1
    How are you checking the amps?  I thought that had to be done under load.
      JonBlakemore | Nov 25, 2008 09:27pm | #2
      Just using a typical multimeter.
  2. Sungod | Nov 26, 2008 01:08am | #3
    It is always just the one bad battery that makes the pack under perform.
    I made a few battery testers out of # 12 copper wire and a 3v flashlight bulb. It tests the battery under load, is cheap, quick, fast and accurate. A digital multimeter might be more detailed, but the bulb takes up less room.
      JonBlakemore | Nov 26, 2008 01:17am | #4
      So how does your setup test it?Do you just throw out the batteries that don't light the bulb, or do you measure the "brightness" somehow?
      1. Sungod | Nov 26, 2008 01:57am | #5
        Bright bulb, it is good. Dull or no light, the battery gets recharged. Mark the ones that are out and if they don't hold a charge, throw it out. Lots of times when charge in pairs one may not be in full contact.
        Some batteries will initially light the bulb, then slowly start dimming.
  3. jagtech | Nov 26, 2008 07:19am | #6
    Testing the batteries under load is the only real way to see if they have any capacity left.  I use my multimeter on the 10 amp range, and BRIEFLY touch the test leads to the battery.  That gives a really good indication of capacity.  I've also found that cheap universal chargers will ruin your nimh batteries in short order.  Since I bought a "smart" charger, and new batteries, I've been extremely happy with the performance of my nimh's.  I wouldn't have believed it til I tried the new charger.  Throw away (recycle) your old weak batteries, tho. The smart charger won't likely help them.
Behind the Scenes of a Concrete Batch Plant
The batch plant is your partner in getting high-quality concrete on your job site.
  • Podcast 549: Energy Upgrades, Chimney Inspections, and Questions About a Home You Might Buy
  • Podcast 549: Members-only Aftershow—Patios vs. Decks
  • Podcast 548: PRO TALK With Design/Build Operations Manager Jessica Bishop-Smyser
  • Strategies for Venting a Roof Valley
BOOKS, DVDs, & MERCH
Shop the Store
    Buy Now
  • 2023 Tool Guide
    Buy Now
    Buy Now
  • Pretty Good House
    Buy Now
  • Shop the Store
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • Issue 311 - November 2022
    • 7 Steps to a Perfect Exterior Paint Job
    • Options for Smarter Home-Energy Tracking
    • The Fine Homebuilding Interview: James Metoyer
  • Issue 310 - October 2022
    • Choosing a Tile-Leveling System
    • Choosing Between HRVs and ERVs
    • Custom Built-in Cabinets Made Easy
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
