I got a call to make some finish floor samples over the weekend. The floor needs to be black and a flat ploy finish. Making the floor black is easy, but the flat ploy is giving me fits. the floor ploy has to be flat finish because when theatre light are on the floor absortes the light.
Efficiency, solar power, and a sensitive kitchen for an 1830s house in New York.
Automotive finishes come to mind for me.
Depending on what they want, the bedliner paint might work.
If they want something that is smooth and flat, I'd talk to a real paint store. They may be able to add a flattening agent to bring down the gloss on a poly floor paint.
Did they really get an audio specialty company suggest they put in a hardwood floor? Thats a huge surface that normally they want covered in an absorbant material like carpet so they don't end up with some nasty reverbs. I know you don't wamt to lose the work but you might be doing them a favor if they you don't know and make sure the flooring has been recommended by the people who are goiing to design and install the home theater.
It would be nice to know what kind of theatre this is and where the floor is. Movie or stage? How large? Is this floor the seating area or the stage?
This is a stage floor at the college I graduated from. The main floor is 30’x80’. There is an extension out into the house seating that is 9’x50’. The college is going with 3” hard maple due to the high traffic of carts being rolled on to the stage. The floor is going to be milled at a local shop close to the job site less than 2 miles away.
Well the classical finish is plain poly, though sometimes a dark laquer is used. I would think you should just want to sample 2-3 different flat poly finishes, unless they indicate they want a dark finish.
I recall that there are additives that can be used to flatten some polys, but I don't recall the details.
