Can you put thinset directly on osb and then screw the 1/2″ durock to it or is it necessary to put down a 1/4″ plywood underlayment and then start the durock install.
A standardized approach, quick-to-install hardware, and a simplified design make building custom casework cost-effective.
Can you put thinset directly on osb and then screw the 1/2" durock to it or is it necessary to put down a 1/4" plywood underlayment and then start the durock install.
