In every issue you'll find...
  • Expert insights on techniques and principles
  • Unbiased tool reviews
  • Step-by-step details to master the job
  • Field-tested advice and know-how
Subscribe Now!
Thinset for Flagstone
DonCanDo | Posted in General Discussion on October 16, 2005 07:14am
I’ll be setting some 12 X 12 flagstone tiles soon (I haven’t seen them yet).  I usually use the flexible bonding stuff (versaflex, fulllex, etc) for ceramic tiles, but I just noticed that HD sells a different thinset for marble and granite.  The package says it’s “perfect for installing natural stone” while versabond says that it’s “ideal for installing natural stone”
Is this just marketing or are there significant differences?
-Don
    Matt | Oct 16, 2005 07:25pm | #1
    Don't know - but have one Q: is the flagstone of uniform thickness?
    1. DonCanDo | Oct 16, 2005 09:23pm | #3
      I don't know since I haven't seen it yet, but that would definitely make it more "interesting" to install.  It's going in an entryway where, I assume, they want the finish height to be level.
  2. FastEddie | Oct 16, 2005 07:57pm | #2
    Maybe the diffeence is the color.  You can't use grey mortar for certain colors of stone cuz it bleeds through.
  3. davidmeiland | Oct 17, 2005 12:50am | #4
    Don't know if it's the same thing, but I have used what my tile store sold as 'marble mortar' and it's a somewhat creamier version of thinset, in white. The white color is to prevent it from showing thru light-colored translucent stone, and the creaminess helps a little when you are working with ungauged stone that needs to be tapped down carefully to be flush. I don't know if there are chemical differences that make it bond better to stone than a tile adhesive would, but there may be. I always like buying tile stuff from a pro tile store because they can answer questions like that.
    EricPaulson | Oct 17, 2005 01:31am | #5
    You are installing Slate, not Flagstone if they are 12x12. Just a WAG anyway.
    The difference you see in the products available at HD are in quality and strength. I'm not sure how the order goes but last time I looked they had thre or four setting mixes.
    I have set slate tiles with thinset.
    Eric
    You better get yourself educaterd before you try to grout those suckers!!
    Grout Release.
    It's Never Too Late To Become
    What You Might Have Been
    [email protected]
    1. DonCanDo | Oct 17, 2005 01:51am | #6
      Grout Release.
      I knew that, but it slipped my mind.  Thanks for the reminder!
    2. DonCanDo | Oct 29, 2005 10:29pm | #7
      You're right.  It's slate.  And it's a real challenge.  Loose flakes, doesn't always cut clean, varying thickness and so far 2 coats of sealer and it's still absorbing.
      Does it eventually stop absorbing?  Is that when I can grout?
      Thanks,
      Don
        EricPaulson | Oct 30, 2005 02:17am | #8
        I rarely seal stone to grout.
        Sealer should be applied after grouting and when it is fully cured. Now what you will end up with is grout with x coats of sealer and stone with x+4 coats of sealer.
        I use grout release. And no; I don't know if you can use it now over the sealer.
        EricIt's Never Too Late To Become
        [email protected]
The Fine Homebuilding Interview: Emily Mottram
A Maine architect speaks about Pretty Good House and biophilic design principles that adapt to all climates.
  • Keep Craft Alive Podcast: Ep. 19, Jesse Neumann, Arborist
  • FHB Podcast: Special Edition With Neil Freidberg of Louisiana Pacific and Kyle Stumpenhorst of RR Buildings
  • DeWalt Recalls 12-in. Sliding Compound Miter Saws
  • Podcast 483: Recalled Electrical Panels, Drainage Behind Brick, and Lazy Additions
BOOKS, DVDs, & MERCH
Shop the Store
    Buy Now
  • Pretty Good House
    Buy Now
  • 2021 Fine Homebuilding Archive
    Buy Now
  • Outdoor Projects
    Buy Now
  • Shop the Store
  • Issue 309 - Aug/Sept
    • 10 Steps to Install Crown Molding on Cabinets
    • How to Get Sturdy Walls Without OSB
    • Choosing the Right Construction Tape for the Job
  • Issue 308 - July 2022
    • Pretty Good House Book Excerpt: Copper Farmhouse
    • 10 Dos and Don'ts for Electric In-Floor Heat
    • A Sturdy Rail for Outdoor Stairs
  • Issue 307 - June 2022
    • How to Raise a Post-Frame Home
    • Trimming Deck Stairs
    • Evolving an Energy-Efficient Envelope
  • Issue 306 - April/May 2022
    • Framing Stairs to an Out-of-Level Landing
    • Building a Zero-Energy Home for Less
    • Good-Looking and Long-Lasting Traditional Gutters
  • Issue 305 - Feb/March 2022
    • The Steady Surge in Residential Solar
    • The Fine Homebuilding Interview: William B. Rose
    • How Good Is Your Air Barrier?
  • twitter
Taunton Network
  • Copyright
  • Do not sell my information
© 2022 The Taunton Press, Inc. All rights reserved.
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
