Thoughts for a fountain?
Yogi | Posted in General Discussion on October 15, 2006 12:13pm
We’ve decided to have a little, tiny fountain/waterfall-  I’ll use some stones and what?  Is there some special mortar mix I buy & mix with water or like that?  Any words of wisdom that might prove helpful?  It’ll be probably two feet tall and four feet long, bent around the corner of the porch next the stairs, not a lot of water with a small recirulating pump-  Any feedback will be appreciated-  Thank you-
  1. stevent1 | Oct 15, 2006 04:32am | #1
    Neat idea. My DW is in the planning stage for a secret garden. About ten X thirty. We have a St. Francis fountain, but are interested in another water feature.
    We will probably look into the freeform neoprene.
  2. piko | Oct 15, 2006 10:10am | #2
    One big problem with anything like mortar is movement/cracking. And absorption...ok two probs. Make sure that there's no likelihood of these - but to safeguard, always have a neoprene or epdm liner.(Purchase at garden centres by the foot.). Sealing any mortar will help, too.
    MarkH | Oct 15, 2006 04:10pm | #3
    Use pond liner rubber, and stones. Skip the mortar for the most part.
    Sphere | Oct 15, 2006 05:23pm | #4
    I made one for an artsy type show for the wife to display, copied from a Hunter I saw in Lowes.
    A copper pan, a few old slates hung with copper nails and grounding braided wire of copper, all suspended on 3/4'' copper pipe frame. drilled 1/8th in holes fro the dribble effect and a rope light for highlite ...
    Sorry no pics till I get it back sometime in the spring.
    Watch the pump size, I wound up getting 3 to get it just right and used clear tubing and hose clamps to connect the joints.
    "have the cold, comfortably numb"
    For Darcy.
  5. andybuildz | Oct 15, 2006 05:30pm | #5
    you need Jerrald Hayes for this one!!
    I'll try and direct him over here.
    Creation arises, is sustained for awhile, and then things change. That’s the dance.
  6. JerraldHayes | Oct 15, 2006 06:42pm | #6
    Yogi Andy emailed me about your question here to get me to throw my two cents in the pond . Using typical mortar mix for joining stones is fine until and unless those mortar joints are be hit by falling water. Mortar mix is not waterproof and the concussive force of the falling water will eventually wear it through and just a tiny pinhole sized leak or hole will empty a small water effect in no time. We reinforce the area where water hits ( and sculpt and build our own artificial stone) with Surface Bonding Cement. It's a product that is used to repair and waterproof block foundation and contains glass fibers for strength and some other additive to give it is waterproof quality.
    Another method we use is a synthetic "mortar" made with epoxy or polyester resin mixed with glass fibers or sand as an aggregate. Expensive and sort of tricky to use but waterproof for sure.
    All that said I think you can even ignore those techniques if you build your whole effect inside a waterproof "tub" using a EPDM rubber pond liner and good underlayment (a geotextile that allows the underside of the tub to breath. Try Aquascapedesigns.com or if your in NJ or the New York metropolitan region you might want to visit Waterworld at Monmouth feed for liners, pumps, advice, and ideas. And try Rockways.co.uk and for some stock fiberglass water features (we only build custom designs). And google around and I'm sure you'll find the other suppliers I just can't think of right now.
Eichlers Get an Upgrade
Performance improvements for the prized homes of an influential developer who wanted us all to be able to own one.
