tile backer for backsplash
| Posted in Construction Techniques on May 21, 2007 12:55pm
I’m in the process replacing cabinets in a kitchen that was renovated only about four years ago. We are also putting a new granite counter top with marble tile backsplash. I’m considering putting cement backer board on only the first six inches or so above the counter (and slightly below it. I figure any serious water penetration is only going to occur near the counter. The tile will be attatched with thin set over the backerboard for the first six inches and then mastic over the drywall the rest of the way up to the upper cabinet. This is a serious labor saver, but am I running any risk of problems down the road.
  1. apiersma | May 21, 2007 05:30am | #1
    I don't know the answer, but my guess is that your better off with the same backer over the whole area. I'd rather go with all drywall, than split the backer. Two different backer might move at different rates.
    JDRHI | May 21, 2007 06:10am | #2
    What kinda marble tile? How thick? What size?
    You shouldn't have any "serious water issues".
    Only reason I'd go with cement backer was if the tile were large and thick.
    J. D. Reynolds
    Home Improvements
    JeffBuck | May 22, 2007 03:48am | #3
    backer won't hurt ...
    but I'd not go thru the trouble.
    plain drywall, primed and painted at least one coat will be just fine 99 times outta 100. Just don't set the dog up there and hose it down.
        Buck Construction
     Artistry In Carpentry
         Pittsburgh Pa
  4. barmil | May 24, 2007 04:36am | #4
    As a homeowner who cooks and cleans the counters, I've never had sufficient water collect at the backspalsh so as to create a penetrating problem. I used mastic for my tile backsplash on the original 30's plaster without a problem. This isn't a bath, so I wouldn't worry about it.
  5. DanH | May 24, 2007 04:48am | #5
    Generally, tile with mastic on drywall works out fine for backsplashes. Caulk the bottom joint and there's no real danger of significant water penetration. (Keep in mind that drywall without any tile is often used in this area -- tile is used primarily to make it easier to clean, not to provide water resistance.)
    However, not sure about the best choices for marble tile.
    But I would agree with the general consensus of all or nothing -- don't split between backer and drywall. If you install backer run it all the way up. And use either all thinset or all mastic -- trying to split between the two will not save labor.
  6. designbing | May 24, 2007 05:13am | #6
    Mastic is not recommended for marble and there is special thinset available for marble. Don't be so cheap with the job when using upscale products.
    Bing
A Step-by-Step for Trimming Stairs
Utility stairs are transformed into a squeak-free finished staircase with straightforward carpentry and easy-to-source parts.
  • Use a Press Tool for Plumbing Connections
  • Remodeling Around Electrical Panels
  • Podcast 567: Soundproofing, Garage Doors, and Rotted Balconies
  • Podcast 567: Members-only Aftershow — Andrew Zoellner’s House
BOOKS, DVDs, & MERCH
Shop the Store
    Buy Now
    Buy Now
  • Pretty Good House
    Buy Now
  • 2023 Tool Guide
    Buy Now
  • Shop the Store
  • Issue 315 - June 2023
    • How to Craft a Copper Roof
    • 5 Lessons from Building in a Cold Climate
    • The Advantages of Cellular PVC Siding
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • Issue 311 - November 2022
    • 7 Steps to a Perfect Exterior Paint Job
    • Options for Smarter Home-Energy Tracking
    • The Fine Homebuilding Interview: James Metoyer
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
