Hello,
I have to install a fairly small amount ( 1 bedroom) of very small (1 1/2″)crowm like moulding.It is all inside corners and I think coping this small stuff might be difficult.(maybe not) (it is not going to be painted,only stained).In my old age I am having trouble remembering how to cut the 45s on a compound miter saw.Something along the lines of upside down and backwards or is that if you want to cope? Or can I lay it flat and bevel it.Saw table becomes the wall or ceiling? If I must cope than I will but miters might be easier in this case.I await your advice.
Thanks ,,Dan
Ensure optimal heat pump performance under wet and potentially damaging conditions with these helpful tips and product recommendations.
Hello,
I have to install a fairly small amount ( 1 bedroom) of very small (1 1/2")crowm like moulding.It is all inside corners and I think coping this small stuff might be difficult.(maybe not) (it is not going to be painted,only stained).In my old age I am having trouble remembering how to cut the 45s on a compound miter saw.Something along the lines of upside down and backwards or is that if you want to cope? Or can I lay it flat and bevel it.Saw table becomes the wall or ceiling? If I must cope than I will but miters might be easier in this case.I await your advice.
Thanks ,,Dan
