Toilet Fange Repair
Glenndouglas | Posted in General Discussion on October 13, 2005 06:33am
I need to replac a toilet flange on a cast iron pipe coming thru a concrete floor. The cast iron pipe is not flush with the floor which makes the top of flange about 1″ above the concrete. What would be the best way to cut off the cast iron pipe flush with the concrete floor.
  1. RickD | Oct 13, 2005 07:17pm | #1
    Instead, I would bring the floor up to the flange - sit the toilet on some kind of small platform, marble or whatever would match your floor.
    But that's just me, I would always try and avoid cutting a cast iron drainpipe.
    My current toilet re-do is on a relatively not ugly white oak platform as I had ripped up the 50's tile flloor down to the original 20's wood floor, a good 1.25 inches lower.
  2. wane | Oct 13, 2005 08:33pm | #2
    you can cut it with a sawzall, patience and some extra blades, but then you need to figure out how to add a flange ..
  3. BigBill | Oct 13, 2005 08:39pm | #3
    Use an angle grinder with a metal cutting wheel.  You can make a clean cut and there are flanges that fit inside the pipe and expand a rubber ring to seal it.
    The platform method is also a good way to go.
  4. mike4244 | Oct 13, 2005 11:27pm | #4
    sawzall and a Lennox cast iron cutting blade. Not all cast iron cuts the same, I have cut thru a 4" pipe in under 2 minutes and sometimes it takes 10 minutes.Hard to fathom why,same type blade ,usually new or lightly used.
    mike
  5. Shacko | Oct 14, 2005 12:11am | #5
    For your information the toilet flange should sit flush with your finished floor, that means the pipe should be approx. 1/4 inch above finish.  If you have a flange on the pipe remove that first, this can be done with a cut-off wheel on a 4 1/2 inch grinder, [if you have one], once you have the flange off proceed to cut the pipe, same tool; you don't have to worry about cutting too short cut it flush if its easier.  Next thing is to go to a plumbing supply and get a c.i. flange that goes on the outside of the pipe with a rubber seal that has bolts that tighten it to the pipe. This pertains to you having a lead joint at the flange?  Luck
    1. Glenndouglas | Oct 14, 2005 08:32am | #6
      It's done. I would have used the grinder if I had read your message first. I used a silsaw to cut slots to the concrete floor, a chisel to mark a line inside and a hammer to break the cast pipe off. The steal flange broke off with a hammer also. Used a flange with the rubber compression ring inside. Worked great.
      1. Shacko | Oct 14, 2005 10:33pm | #7
        Glad everything worked out.  Lots of luck.
PVC for a Rot-Proof Fence
Built with rot-proof material with traditional tools and techniques, this classic border is engineered to never sag.
Get an overview of the process of creating a traditional-style fireplace that burns well and meets current building codes from experienced mason Mike Mehaffey.
  • Podcast 551: Power Tool Batteries, Building as a Third Career, and High DIY
  • Podcast 551: Members-only Aftershow—Badly-Built Homes
  • Podcast 550: PRO TALK With Carpentry Program Instructor Sandy Thistle and Graduate David Abreu
  • Podcast 549: Energy Upgrades, Chimney Inspections, and Questions About a Home You Might Buy
BOOKS, DVDs, & MERCH
Shop the Store
    Buy Now
  • Pretty Good House
    Buy Now
    Buy Now
  • 2023 Tool Guide
    Buy Now
  • Shop the Store
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • Issue 311 - November 2022
    • 7 Steps to a Perfect Exterior Paint Job
    • Options for Smarter Home-Energy Tracking
    • The Fine Homebuilding Interview: James Metoyer
  • Issue 310 - October 2022
    • Choosing a Tile-Leveling System
    • Choosing Between HRVs and ERVs
    • Custom Built-in Cabinets Made Easy
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
