Torch-down roof fire
davidmeiland | Posted in General Discussion on September 25, 2005 04:41am
Got called out with the volunteer FD last night to a fire at the county administration building. It’s a one-story flat-roof block building that a roofer has been working on during the past week. The roof is 2x10s with plywood sheeting and roofing over, and sheetrock under, with FG insulation between.
At about 2:30 AM Saturday morning a passerby noticed smoke coming from a spot on the roof. No work had been done since at least 5 PM Friday, almost 10 hours prior. We extinguished a small fire that had been smoldering in the ceiling/roof assembly for at least that long. One of the 2×10 joists was burned completely thru with extension into joist bays on either side. Remarkble how long a fire can burn, and go undetected, in circumstances like that.
Second time this has happened here in the past 6 months. Watch those torches, folks.
  1. Piffin | Sep 25, 2005 05:38am | #1
    one of the main reasons I don't care for torchdown modified in most circumstances is the close experience I had with one of those exciting events
    1. DanT | Sep 25, 2005 12:04pm | #2
      About 5 years ago one of the larger roof companies that still used modified roofing in our area burned down a doctors office using it.  The A/C was running and created a slight negative pressure in the building.  When the torch hit an area where the deck had a small gap the flame go sucked in.
      According to a fire Captain I know the fire started small just like you describe but in this case the negative pressure fed oxegen to it and fanned the flames sort of speak.  Brick building so it didn't burn it to the ground but they had a really big sky light after that!  The company ceased using it that day.  DanT
Critical Details for Ductless Heat Pumps
Trouble-free performance begins with properly installed line sets that pass rigorous testing for leaks.
  • Podcast 551: Power Tool Batteries, Building as a Third Career, and High DIY
  • Podcast 551: Members-only Aftershow—Badly-Built Homes
  • Podcast 550: PRO TALK With Carpentry Program Instructor Sandy Thistle and Graduate David Abreu
  • Podcast 549: Energy Upgrades, Chimney Inspections, and Questions About a Home You Might Buy
BOOKS, DVDs, & MERCH
Shop the Store
    Buy Now
    Buy Now
  • 2023 Tool Guide
    Buy Now
  • Pretty Good House
    Buy Now
  • Shop the Store
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • Issue 311 - November 2022
    • 7 Steps to a Perfect Exterior Paint Job
    • Options for Smarter Home-Energy Tracking
    • The Fine Homebuilding Interview: James Metoyer
  • Issue 310 - October 2022
    • Choosing a Tile-Leveling System
    • Choosing Between HRVs and ERVs
    • Custom Built-in Cabinets Made Easy
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
