Tornado safe room on slab built out of lumber or?
scoutm38 | Posted in General Discussion on April 16, 2020 06:38pm
Is there any acceptable way to do tornado room on ranch slab?
  1. oldhand | Apr 16, 2020 08:57pm | #1
    No such thing as fail safe but you can sure harden the target. Look up FEMA recommends.
  2. jlyda | Apr 17, 2020 01:58am | #2
    Best to buy a safe room already built. My parents moved into a slab on grade home in tornado alley. We thought of building a safe room in the garage, but found cheaper and easier to buy it already made. The big issue for us was when we considered the door to the safe room. You need a door that can potentially push tons and tons of debris as your house could possibly all fall in front of the door. Need to be able to get out!
  3. scoutm38 | Apr 17, 2020 11:45am | #3
    That,s my fear if I used crawlspace----I actually hardened up room in garage with the boiler so I could cut water and gas plus have an electric chain saw in there.
    I understand i could use 3/4" on walls and real plywood on roof as both were a higher level of protection. then for safe room use 2 3/4" plywood together would give a high level of breakthru from debris.
Behind the Scenes of a Concrete Batch Plant
The batch plant is your partner in getting high-quality concrete on your job site.
Get an overview of the process of creating a traditional-style fireplace that burns well and meets current building codes from experienced mason Mike Mehaffey.
  • Podcast 549: Energy Upgrades, Chimney Inspections, and Questions About a Home You Might Buy
  • Podcast 549: Members-only Aftershow—Patios vs. Decks
  • Podcast 548: PRO TALK With Design/Build Operations Manager Jessica Bishop-Smyser
  • Strategies for Venting a Roof Valley
BOOKS, DVDs, & MERCH
Shop the Store
  • 2023 Tool Guide
    Buy Now
    Buy Now
  • Pretty Good House
    Buy Now
    Buy Now
  • Shop the Store
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • Issue 311 - November 2022
    • 7 Steps to a Perfect Exterior Paint Job
    • Options for Smarter Home-Energy Tracking
    • The Fine Homebuilding Interview: James Metoyer
  • Issue 310 - October 2022
    • Choosing a Tile-Leveling System
    • Choosing Between HRVs and ERVs
    • Custom Built-in Cabinets Made Easy
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
