I am considering purchasing a small, open utility trailer (5-6′ wide, 10-14′ long). Looking for advice from your experience. Single axle or tandem? what lengths make the most sense? It would be used mainly to haul materials.
Jon Blakemore
Jon Blakemore
At that length, I'd probably look for a "landscaper's special". Most trailer outlets I've been to sell them: they're the ones that they haul lawnmowers around on, a sort of mini-float. Good proven design with an excellent resale value if you take care of it.
*I actually bought a "carhauler" style; same setup, flat, 16' long, I believe 5' wide. Got it to haul small equipment (mini-excavators, trenchers, etc.), and wall panels built in the shop to the jobsite. Mine has ramps instead of the "fold down" grating landscapers have. In my area, I had basically two choices; a factory built model (May, MacLander, etc.), or the cheaper ones you see advertised everywhere. Difference is usually in amount of bracing and size of channel for frame, and in electronics; more expensive ones have brakes and breakaway kits installed. I went with the more expensive one, mainly for the size and the brakes; hauling a 5500lb. Kubota excavator (which is the limit for my truck), with no trailer brakes just made me just a little too nervous. All in all, a good trailer, since I only have one, but like any other single purpose tool, it has it's drawbacks. Sometimes it's a little too small (tractor with brush hog and loader sticks out), and sometimes way too big (moving a lawn mower for instance). But, I also wanted to get as big a trailer as I would probably need. Hope this helps.
*Jon,I have three trailers. Take it from me, the number one consideration is a place to park it. I live on an acre+ and the darn things are always in the wrong place.For construction use, I like a 16 foot tandum with brakes. You can hall 20' material with a red flag. You can also haul 16' long sheets of drywall. With brakes you can haul heavy loads, i.e., a tractor or a mess of cinder blocks. Tandum carries more weight and rides better. If you buy a 12' or 14' single axle there will be days you wished you had gone 16' tandum. Around here (NE Ark/SE Mo) you can get one for $800 +/-. Good luckSteve
I am considering purchasing a small, open utility trailer (5-6' wide, 10-14' long). Looking for advice from your experience. Single axle or tandem? what lengths make the most sense? It would be used mainly to haul materials.
Jon Blakemore
