Transistion from tile to wood flooring
housemom | Posted in General Discussion on October 2, 2006 03:40am
From the attached pictures I hope you can see that I have a one inch question.
What is the best way to transistion from the tile floor to the hard wood now that the carpeting has been pulled out and I am going to refinish the floor? With the wall to wall there the one inch was nothing but now it seems like I am walking into the Grand Canyon.
Advise please.
  1. cliffy | Oct 02, 2006 03:49am | #1
    I would be going to  Lacasse Fine Wood Produsts (my local hardwood supplier) to pick up one of their custom made transition strips.  Yoou can ge the thickness you want with a bevel down to the wood. At a couple bucks a foot you can't get much easier.
    Have a good day
    Cliffy
    1. housemom | Oct 02, 2006 04:03am | #2
      Thanks for that idea. Where is your local shop at? Please tell me Chicago....I can only hope. But I'll try to find some who can do something like this if your someone else.
      Thanks again for being so quick.
      1. cliffy | Oct 02, 2006 04:36pm | #4
        Sorry , I'm in Canada, but you should be able to find the piece locally.
        Have a good day
        Cliffy
        1. housemom | Oct 14, 2006 06:09pm | #5
          Just an update- I was able to get the transitions made but was wonderign if there is a standard spacing for the screws to mount them in position?  From the 45 degree angle where they meet --how close do allow a screw hole to get and how far apart after that.
          1. alrightythen | Oct 14, 2006 06:15pm | #6
            I wouldn't bother with the screws.
            PL leaves no srew holes.
          2. jpeeks | Oct 14, 2006 06:18pm | #7
            I would nail it with a finish nailer or hand nail with finish nails and a nail set  if you don't have a nail gun.Screws would be unsightly.
            IMERC | Oct 14, 2006 06:52pm | #8
            PL Premium and a few small finish nails to hold it in place till the PL sets..
          4. sharpblade | Oct 15, 2006 01:16am | #9
            Or replace "a few small finish nails" with "an old car battery at each end"  :-)
          5. alrightythen | Oct 15, 2006 09:06am | #10
            PL is pretty sticky stuff..I've done several transition strips using PL  including several where CC slab was underneath, unless your strip has a warp in it. I've never had the need for nails or even weights. simply apply Pl press and don't touch till it sets.
            years later still looks great . If you do have any kinda warp then weigh it done as you suggest. You'll know when you set it down if it needs weights or tacks.
  2. JTC1 | Oct 02, 2006 05:13am | #3
    This is not an unusual problem.  Like Cliffy said a beveled transition piece will solve the problem.
    If you are having the floors professionally refinished, the refinishing company should be able to supply and install the transition piece. If you are planning to refinish the floors yourself, you will have to make the piece yourself.  For some reason I think Bruce Hardwood flooring makes such a piece (check with the flooring department at the local big box store).  It looks like you only need about 3' or so - it will be relatively cheap.  Match species and stain and you will be good to go.  Even if the Bruce piece is the wrong stain you could strip and sand before installation.  If the stock piece is too thick - plane the bottom side, too thin - shim it up a bit.
    Good luck!
    Jim
Behind the Scenes of a Concrete Batch Plant
The batch plant is your partner in getting high-quality concrete on your job site.
  • Podcast 549: Energy Upgrades, Chimney Inspections, and Questions About a Home You Might Buy
  • Podcast 549: Members-only Aftershow—Patios vs. Decks
  • Podcast 548: PRO TALK With Design/Build Operations Manager Jessica Bishop-Smyser
  • Strategies for Venting a Roof Valley
BOOKS, DVDs, & MERCH
Shop the Store
    Buy Now
  • Pretty Good House
    Buy Now
  • 2023 Tool Guide
    Buy Now
    Buy Now
  • Shop the Store
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • Issue 311 - November 2022
    • 7 Steps to a Perfect Exterior Paint Job
    • Options for Smarter Home-Energy Tracking
    • The Fine Homebuilding Interview: James Metoyer
  • Issue 310 - October 2022
    • Choosing a Tile-Leveling System
    • Choosing Between HRVs and ERVs
    • Custom Built-in Cabinets Made Easy
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
