Treated Picnic Shelter from Sweet Gum
Hey folks,
Under some circumstances sweet gum can produce really nice finished wood projects but overall it’s not the best working material around.
It also stinks when it burns so firewood is out…smells like a pale of used baby diapers.
So that leaves the 16 I’m taking down in the yard for another project…..a picnic shelter.
Question: What is the best way to “diy home” preserve these as inground posts for a shelter?
Can I cut them green and stick ’em in a 5 gallon pail of wood preservative for 30 days or something?
Pedro the Mule – Need a sweet idea
That stuff rots faster than poplar. I can't imagine anything you can do short of pressure treating that would make it suitable for ground contact.
I like to soak the ends of boards that i know are going to be exposed to water, temperature swings, and sun.
I like to use whatever I have on hand that will penetrate and fill the grain with something other than air.
Wood preservative sounds like a good idea if you have some. Are you talking about the green stuff? I also had some clear stuff that was for preserving wood. Both of those have some nasty chemical in them that kills most anything.
If the wood preservative is real thin I like to follow up with something a little thicker afterwards. Some of them are so thin that they don't fill the grain like I like. But they do penetrate deeper into the piece.
It's hard to tell what the outcome will be but it is a good start.
I figure pressure treated wood came about for speed as much as anything. They don't have the time to soak lumber in a commercial operation.
I have never seen it, or done it, but I have heard of drilling a hole into posts starting a few inches off the ground. You drill at an angle into the center of the posts. Then once or twice a year you fill up the hole with a wood preservative. You can stick a cork in hole. This keeps a flow of wood preservative going into the center of the post.
Will Rogers
