FHB Logo Facebook LinkedIn Email Pinterest Twitter Instagram Tiktok YouTube Plus Icon Close Icon Navigation Search Icon Navigation Search Icon Arrow Down Icon Video Guide Icon Article Guide Icon Modal Close Icon Guide Search Icon Skip to content
Trenched footing?
Craigabooey | Posted in Construction Techniques on February 3, 2006 07:40am
Hello there! I am getting ready to build a 10×12 ft kitchen extension on my home. Above it will be a second story bedroom. My architect is telling me I have to use a trenched footing. The hole house is slab on grade, no crawlspace, no basement. Why cant I just dig down to below the frost line with an 8″ wide footing and flare out the bottom. This way I can pour the slab monolithically. Wouldnt this accomplish the same thing? To do it his way I will need to excavate more than I want to, and there is very limited space. There are also concerns I have for not wanting a back hoe in there (tearing up my entire lawn, breaking the sewer line etc.) What do you think? How do you pour the slab if you have to set up forms etc?
  1. dgbldr | Feb 03, 2006 08:22pm | #1
    Ask the architect why not. We can't guess at all the possible circumstances and his thinking. Then let us know what he says.
    DG/Builder
    Huck | Feb 03, 2006 08:22pm | #2
    I think the footing size is the issue, not whether its dug by hand or machine.  "Trenched" just refers to the fact that the footing is formed by a sub-grade trench.
    edited to add: Forms are necessary regardless.  Monolithic pour is OK - we do it all the time here in So. Cal.  Just tie the footing rebar into the w.w.m. or slab rebar, if any.
    Edited 2/3/2006 12:35 pm by Huck
    McDesign | Feb 03, 2006 08:27pm | #3
    I just poured a monolithic slab on grade (about 11" above finished grade, to match an existing house slab) like you want to do, 16' X 24'.  It worked fine, and satisfied local code and the inspector, but here near Atlanta we don't have to go so deep, or use foam underneath.  It does use more gravel, because it kind of ramps down into the footing "trench", but I love only having one 'crete truck delivery.
    Once you get the gravel placed, the 6-mil plastic under the slab part gets pinned down and keeps gravel from slumping into the trench.  Fill the trench first all around, then fill your slab area.
    I have an idea where you use rebar stakes and Hardiplank to define the inner edge of the footing, to minimize the concrete use - I didn't do that here, but I think it could work . . .
Double Dormer Transformation
This historic schoolhouse was transformed into a stunning four-bed, three-bath home with ocean views and a modern open-concept design.
  • Balancing Window Selections for Performance and Budget
  • Issue #320 – Dec. 2023/Jan. 2024
  • Podcast 607: Wood Foundations for Winter Builds, Adding Headroom, and Aeroseal for Leaky Ducts
  • Podcast 607: Members-only Aftershow—Holiday Gifts for Home-Building Enthusiasts
BOOKS, DVDs, & MERCH
Shop the Store
  • Pretty Good House
    Buy Now
  • Code Check Complete 3rd Edition
    Buy Now
  • 2023 Fine Homebuilding Archive
    Buy Now
  • 2024 Tool Guide
    Buy Now
  • Shop the Store
  • Issue 320 - Dec 2023/Jan 2024
    • How to Reuse Salvaged Wood
    • Chainsaw Retrofit and Energy Performance
    • Maximize HVAC Efficiency
  • Issue 319 - November 2023
    • Nearly Net-Zero ADU
    • An Easy Approach to Coffered Ceilings
    • Understanding Types of Roof Vents
  • Issue 318 - October 2023
    • Make Mudsills Square and Level
    • Turn Up the Heat With Induction Cooktops
    • The Fine Homebuilding Interview: Lloyd Alter
  • Issue 317 - Aug/Sept 2023
    • Finishing Drywall With Seamless Results
    • A Flat Roof in a Cold Climate
    • Compact Cordless Shop Vacs
  • Issue 316 - July 2023
    • Timber-Framed Solar Canopies
    • Build a Transom Above a Stock Door
    • Understanding Toilet Design and Efficiency
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
Start your subscription today and save up to set_percent%
