Tyvek on 1″ rigid foam
alfie | Posted in Construction Techniques on February 1, 2009 07:05am
I am building a house and installed 1†rigid foam on the exterior of the OSB sheathing. The original intent was that the foil on the foam would be the weather barrier, as per Dow’s Tuff-R product specs. All joints are taped with Dow Weathermate construction tape, as specified.
The foam has gotten damaged here and there due to the usual things that go on at a construction site. I have decided to Tyvek the exterior, on top of the foam (after repairing the foam).
Question is, how do I install the Tyvek? With 3/8†staples normally used for fastening Tyvek, the Tyvek will blow off the foam before we get to installing the siding.
Suggestions on fastening the Tyvek on top of foam?
  1. BoJangles | Feb 01, 2009 07:13pm | #1
    Just tack it with a minimal amount of 2" roofing nails.
    We don't usually use Tyvek over foam unless it is the semi- permeable stuff used to remodel old houses with the interior wall intact.
    Are you sure you even need the Tyvek?
    Edited 2/1/2009 11:16 am ET by BoJangles
    1. alfie | Feb 01, 2009 07:25pm | #2
      Can't say I'm sure, but am thinking of it.
  2. Piffin | Feb 01, 2009 09:05pm | #3
    Plasticap nails.
  3. reinvent | Feb 01, 2009 10:10pm | #4
    Don't waste your money. Foil faced foam doesn't breath. I would however put up a rain screen like 'home slicker' so the siding can dry out.
    http://www.umass.edu/bmatwt/publications/articles/housewraps_feltpaper_weather_penetration_barriers.html
    http://www.buildernewsmag.com/viewnews.pl?id=21
    1. alfie | Feb 01, 2009 10:53pm | #5
      I do understand about the foil face. However, it is damaged all over the place, so I am thinking of a belt and suspenders approach with Tyvek.
      1. arcflash | Feb 02, 2009 04:07am | #6
        Second the plastic caps. The staple gun is cheaper than the plastic cap nail gun. How thick is the foam? Id make sure that the plastic cap nails/staples penetrate deep enough into the OSB. The caps have a better shear resistance (good for that high wind you were talking about), and they also bump out the siding to allow a little air movement (not as much as a rainscreen wall, but more than just t-50 staples).
        1. Piffin | Feb 02, 2009 07:52am | #9
          "The staple gun is cheaper than the plastic cap nail gun."I doubt a one time DIY is going to need to buy a gun. He probably has a hammer that works just fine.
          1. alfie | Feb 08, 2009 10:50am | #10
            So here is the conclusion of this episode:1. After some back and forth the idea of the house wrap has been abandoned. We'll just go with repairs to the foam.2. The cap nailer I had ordered from my framer's favorite line of nailers arrived. He took one look and pronounced it site unworthy (my words). The magazines for nails and caps are both plastic. He said one fall of the gun, and the nailer would be a write-off.
          2. tom21769 | Feb 08, 2009 03:00pm | #11
            Another useful tool for a job like yours is a j-roller. Use it to smooth and firm down the tape over your seams. This will give you better results than you get from hand pressure alone.Amazon has them for $10 or $15. Using a circular saw and guide rail to cut the foam, I often can get very tight seams between the panels. Otherwise I try to achieve about a quarter inch gap and shoot in the minimally expanding foam to about half the depth of the seam, or a little more. Then tape over that.
            Dam_inspector | Feb 08, 2009 04:48pm | #12
            Was that a Senco (grip rite) cap stapler? I bought one off eBay brand new for $26! No one seemed interested in bidding on it, they normally sell for a couple hundred.It's nice, but there is a lot of plastic, and the staples are only 7/8 inch long. If you pick it up wrong it will flip the staple magazine open and the staples fall out. I did have to order the staples and caps, the closest local supplier is about 27 miles from me.I ordered the staples from tool barn, they have awesome service, and some of the best prices.
          4. alfie | Feb 08, 2009 05:43pm | #13
            It was a Hitachi NV50AP3. I bought it a decent price from Amazon. All the others were about +$100.
            Dam_inspector | Feb 08, 2009 07:03pm | #14
            That is tough plastic, polycarbonate.
          6. alfie | Feb 08, 2009 07:08pm | #15
            I know what you mean - but my framer had made up his mind and he was not going to be lead astray by facts.
    Dam_inspector | Feb 02, 2009 05:05am | #7
    Just put the good aluminum tape over the defects. I'm assuming they aren't huge, but if they are the bad sections could be cut out and replaced.
    1. alfie | Feb 02, 2009 06:17am | #8
      The rigid foam is 1" Dow Tuff-R. It is made up of a "closed-cell polyisocyanurate foam core", and foil facers. Besides the cost of material and labor to install, I wonder if there is a down-side to installing Tyvek over it.
Achieve a Flat Drywall Finish
These products and methods result in the clean lines essential to a midcentury-modern aesthetic.
  • Use a Press Tool for Plumbing Connections
  • Remodeling Around Electrical Panels
  • Podcast 567: Soundproofing, Garage Doors, and Rotted Balconies
  • Podcast 567: Members-only Aftershow — Andrew Zoellner’s House
BOOKS, DVDs, & MERCH
Shop the Store
  • Pretty Good House
    Buy Now
    Buy Now
  • 2023 Tool Guide
    Buy Now
    Buy Now
  • Shop the Store
  • Issue 315 - June 2023
    • How to Craft a Copper Roof
    • 5 Lessons from Building in a Cold Climate
    • The Advantages of Cellular PVC Siding
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • Issue 311 - November 2022
    • 7 Steps to a Perfect Exterior Paint Job
    • Options for Smarter Home-Energy Tracking
    • The Fine Homebuilding Interview: James Metoyer
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
