under deck dry storage
hcalvert | Posted in Construction Techniques on February 23, 2007 10:58am
i would like to build a deck above a walk out basement. the walk out has concrete wall on two sides and door to the basement on the third side and is open on the forth side. i would like to have water tight deck w/ a roof above which could be used as an open deck also. the first floor of this deck would be open to wind driven rain and snow.
looking for ideas. i will be installing garage type door on the forth side building walls on the concrete sides and opening up the basement side. would like to store my bikes under the deck.
Thanks in advance for your help.
  1. woodroe | Feb 24, 2007 03:03am | #1
    Here's the short version
    Build new floor with pitch to drain. 3/4" plywood atop joists. 1/2" fiber board underlayment and EPDM membrane on plywood. 2 x 2 treated sleepers with EPDM cushion glued to bottom of sleepers, decking screwed to sleepers.
  2. iluvgear | Feb 24, 2007 02:12pm | #2
    A couple of thoughts for you.  Most products are probably best when designed in from the start but everything is adaptable.
    http://www.dekdrain.com/
    http://www.underdeck.com/default.aspx
    http://www.bobshowto.com/Deck-Ceiling.htm
  3. WINSTALL | Feb 24, 2007 05:18pm | #3
    Build "normal" joist system, use T&G plywood glued & screwed, pitch the floor for drainage 1" every 8'0". Nail a 1 x 3 band around perimeter flush with the sub floor. Flash side walls that touch the deck surface 10" up the wall and 8" out on the deck surface. Flash the deck surface up and under any patio doors. Then FIBERGLASS the surface just like it was a boat!!!! Best and only water proof deck I know of.
    Pick your color and enjoy.
  4. myhomereno | Feb 24, 2007 10:25pm | #4
    I am facing the same situation in my deck construction. I like the idea of the http://www.dekdrain.com/ system. My deck is 35x12 feet in size and it will have a roof over it. I will probably use a standing seam metal roof with some skylights in it. There is still a great chance of wind driven rain getting on the deck.
    A friend has a covered Deck and used fiberglass over plywood for the deck. Over top of that he uses outdoor carpet. It is easy to clean and doesn't get hot in the sun. The fiberglass gets very hot in the sun if its not covered. The same goes for vinyl decking material over plywood (I had that before), in the sun you can't walk barefoot over it.
    I will probably go with wood as a decking material this time. Western red Cedar is the popular choice were I live. I read a lot about other tropical hardwoods like Ipe but I don't know the cost of it here in BC.
    Martin
  5. 12aj | Feb 25, 2007 02:56am | #5
    I used a deck coating product from Gaco called GacoDeck, which you apply over an exterior plywood deck (built using standard construction techniques) and am very pleased with the results,  no mess, easy clean up, went on with roller...be sure to take your time doing the joint seam prep though, as it WILL show through the coating ..good luck
    http://www.gacoretail.com/default.html
    Edited 2/24/2007 7:08 pm ET by 12aj
  6. peteshlagor | Feb 25, 2007 06:18pm | #6
    http://www.miracote.com  Search for their Miraflex II decking system.
    Specifically, the procedure is:
    http://forums.taunton.com/tp-breaktime/messages?msg=79912.13
  7. peteshlagor | Feb 25, 2007 06:28pm | #7
    This is where I got stopped by the snow.  This decking goes on when I 've got warm enough weather - 50ish.
    Edited 2/25/2007 10:29 am ET by peteshlagor
Solar Shingles in Austin
A Tesla roof powers this five-bedroom Texas home and then transfers extra energy to the power grid.
  • Podcast 551: Power Tool Batteries, Building as a Third Career, and High DIY
  • Podcast 551: Members-only Aftershow—Badly-Built Homes
  • Podcast 550: PRO TALK With Carpentry Program Instructor Sandy Thistle and Graduate David Abreu
  • Podcast 549: Energy Upgrades, Chimney Inspections, and Questions About a Home You Might Buy
BOOKS, DVDs, & MERCH
Shop the Store
    Buy Now
  • Pretty Good House
    Buy Now
    Buy Now
  • 2023 Tool Guide
    Buy Now
  • Shop the Store
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • Issue 311 - November 2022
    • 7 Steps to a Perfect Exterior Paint Job
    • Options for Smarter Home-Energy Tracking
    • The Fine Homebuilding Interview: James Metoyer
  • Issue 310 - October 2022
    • Choosing a Tile-Leveling System
    • Choosing Between HRVs and ERVs
    • Custom Built-in Cabinets Made Easy
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
