I am familiar with a couple of different ways to install undermount sinks in solid surface counters and would like to get some feedback on what is generally viewed as the “difinitive” method.
One way I have done this is to cut the opening in the top a little bigger than the inside bowl size so that there is a crisp joint between the counter-top and the flange of the sink. I would finsh this off with a small bead of silicone caulk.
The other method has been to cut the opening in the top smaller than the inside bowl size by about 3/8″ to 1/2″(depending on the radius of the round over at the top of the bowl) so that the top overhangs the sink bowl. A silicone joint is still required at the sink/top joint, but it doesn’t have to be pretty since it’s out of view.
Thanks for any input.
I am familiar with a couple of different ways to install undermount sinks in solid surface counters and would like to get some feedback on what is generally viewed as the "difinitive" method.
The other method has been to cut the opening in the top smaller than the inside bowl size by about 3/8" to 1/2"(depending on the radius of the round over at the top of the bowl) so that the top overhangs the sink bowl. A silicone joint is still required at the sink/top joint, but it doesn't have to be pretty since it's out of view.
