I am replacing a 40 foot wall on a building build around 1920,and there is only about 6 inches from the out side of the wall to a rock cliff. so I need to prefab the new walls in 4 foot sections it will be a 2 by 4 wall with 1/2 cdx and hardy panel siding, that’s the only way I have figured how to do it as I have no access to the outside at all. question is were the panels seem together how to seal it I was thinking about battens over the seems but not even sure if I can get back there to nail em off! any help or suggestions would be most welcome thank you
Performance improvements for the prized homes of an influential developer who wanted us all to be able to own one.
Is there any special reason to build the wall in such small sections?
You could build the wall as a single unit and rent or borrow some wall jacks to stand it with.
Terry
thanks fo the reply, problem is the old wall is gone and I have a temp partition bearing wall about five feet in to support the flat roof,no room to work, the wall I need to build will be 10 feet high
