FHB Logo Facebook LinkedIn Email Pinterest Twitter Instagram Tiktok YouTube Plus Icon Close Icon Navigation Search Icon Navigation Search Icon Arrow Down Icon Video Guide Icon Article Guide Icon Modal Close Icon Guide Search Icon Skip to content
Vent kitchen hood down?
user-981828 | Posted in General Discussion on April 25, 2016 08:59am
On our current project’s kitchen hood venting, the shortest run with the least number of turns is actually up to a soffit, across the ceiling, and *down* behind a shallow cabinet before going out to daylight. Any reasons we shouldn’t be doing this?
Thanks!
  1. DanH | Apr 25, 2016 09:25pm | #1
    You should check the specs & installation info for the hood (likely you can find them online) and see if this is allowed.
    You want to avoid any low spots in the duct that could collect moisture or grease.
  2. calvin | Apr 25, 2016 09:55pm | #2
    User
    your hood specs will give you the figures to calculate max total run length with deductions for the turns etc. if the numbers allow I would not be concerned with the run you laid out....
    unless,
    you do some sort of extreme cooking.
    after many kitchen remodels I think I've only seen one exhaust problem.  A whole lot of wok cooking and everything within a few ft of that stove was sticky.
    I wonder the infatuation of kitchen exhausts.  Must be the elimination of moisture or heat, but personally there's nothing like the aroma of a kitchen.
Details for Integrating an Addition
In this video, Jon overviews the elements of the addition, including building a deck-ledger-style floor system, closing off windows and doors, and framing the roof.
  • Balancing Window Selections for Performance and Budget
  • Issue #320 – Dec. 2023/Jan. 2024
  • Podcast 607: Wood Foundations for Winter Builds, Adding Headroom, and Aeroseal for Leaky Ducts
  • Podcast 607: Members-only Aftershow—Holiday Gifts for Home-Building Enthusiasts
BOOKS, DVDs, & MERCH
Shop the Store
  • 2023 Fine Homebuilding Archive
    Buy Now
  • 2024 Tool Guide
    Buy Now
  • Pretty Good House
    Buy Now
  • Code Check Complete 3rd Edition
    Buy Now
  • Shop the Store
  • Issue 320 - Dec 2023/Jan 2024
    • How to Reuse Salvaged Wood
    • Chainsaw Retrofit and Energy Performance
    • Maximize HVAC Efficiency
  • Issue 319 - November 2023
    • Nearly Net-Zero ADU
    • An Easy Approach to Coffered Ceilings
    • Understanding Types of Roof Vents
  • Issue 318 - October 2023
    • Make Mudsills Square and Level
    • Turn Up the Heat With Induction Cooktops
    • The Fine Homebuilding Interview: Lloyd Alter
  • Issue 317 - Aug/Sept 2023
    • Finishing Drywall With Seamless Results
    • A Flat Roof in a Cold Climate
    • Compact Cordless Shop Vacs
  • Issue 316 - July 2023
    • Timber-Framed Solar Canopies
    • Build a Transom Above a Stock Door
    • Understanding Toilet Design and Efficiency
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
Start your subscription today and save up to set_percent%
