Wallpaper/drywall repair
Pascanale | Posted in General Discussion on April 18, 2007 11:41am
I have a client stripping wallpaper before I apply crown, chair rail, baseboard and a new floor. I forewarned them to get a steamer to aid in the stripping. Still its taking the paper off the drywall. I stopped by and determined the wallpaper was applied directly to the the drywall without a primer of paint–no wonder. Most of the wall is now suffering from slight peelings. What’s a good prep for this before painting or do we paint it (primer) then get a plasterer? the surface is not gouged, just rough in places.
Pascanale
  1. FastEddie | Apr 18, 2007 11:55pm | #1
    If the paper is torn and the gypsum cores shows, then you really need to skim coat those areas.  If the paper is just roughed up ... I might still skim coat.
    1. Pascanale | Apr 19, 2007 04:40am | #7
      The consensus is at a minimum prime with oil base Zinser/Kiltz which is what I use on any plaster, then sand where needed. If that is sufficient, go ahead and paint, otherwise, skim coat or more.
      Thanks All,
      Pascanale
      1. Piffin | Apr 19, 2007 01:38pm | #11
        no- the minimum is to plan to skim coat.
  2. DanH | Apr 19, 2007 12:00am | #2
    There are various solutions, depending on how bad the situation is, how much of an area is involved, and how fussy the customer is.
    Simplest case you need to prime/paint the surface with a non-water-based material (oil/shellac) to stiffen and lock down the loose paper fibers. Sometimes that and a little sanding and spot filling is all that's needed.
    Worst case, you need to skim coat the entire wall or replace the wallboard.
  3. Ipaint | Apr 19, 2007 12:07am | #3
    Skim coat. Sorry, but there's no way around it.
  4. Piffin | Apr 19, 2007 02:15am | #4
    A skim coat in the minimum. Bad enough and it needs a mesh coat too.
  5. paperhanger | Apr 19, 2007 03:04am | #5
    sand when dry, use Gardz from Zinnser to prime before you mud, the results over the Guardz will be awesome.
  6. alwaysoverbudget | Apr 19, 2007 03:29am | #6
    if your just into the paper and it's fuzzy. prime with  kiltz oil base let dry. then i come back with my pc orbital sander and sand the fuzzies smooth. if there are still rough spots you will need to skim them, then need to reprime with kiltz again. thats how i do it! there's 10 other answers here so pick your poision. larry
    1. DonCanDo | Apr 19, 2007 04:47am | #8
      I agree with your approach.  Oil primer (Kilz is good, but there are others too), lightly sand, skim coat and oil primer again.
      The reason for the first coat of oil primer is that once the top paper layer of drywall is compromised, the lower layers of paper will bleed through water-based primer so you need a stain blocker.  Also, oil sticks better.
      Water-based primer MIGHT work after skim-coating, but I had trouble one time and now I use oil for the 2nd coat when I've used oil for the 1st.
      1. Pascanale | Apr 19, 2007 04:56am | #9
        thanks for the endorsement. I'll be using exclusively oil base (Zinser) since I've had similarly marginal success with water-base on fresh plaster. I prefer to use the old plaster "Diamond Coat" because its truly harder plaster, too.
        Pascanale
        1. dovetail97128 | Apr 19, 2007 05:27am | #10
          What others said. very light sanding , Kilz, very light sanding, top coat will reveal any "bubbles " where the paper lifts off the rock , cut those out , re-Kilz and top coat those areas again.
        2. paperhanger | Apr 19, 2007 02:37pm | #12
          use the Guardz, its water base, does not raise the paper of the sheetrock, much better then the oil base
          1. Pascanale | Apr 19, 2007 08:47pm | #13
            Ok, water based, which I'm surprised since drywall is susceptible to water. Whatever. I'll then skimcoat--the surface isn't gouged so, we should not need anything more.
            The Guardz product is made by who? I use Sherwin Williams and Zinser primarily.
            Thanks,
            Pascanale
            BillHartmann | Apr 19, 2007 09:49pm | #14
            It is a Zinsser Product.http://www.zinsser.com/product_detail.asp?ProductID=27.
Behind the Scenes of a Concrete Batch Plant
The batch plant is your partner in getting high-quality concrete on your job site.
  • Podcast 551: Power Tool Batteries, Building as a Third Career, and High DIY
  • Podcast 551: Members-only Aftershow—Badly-Built Homes
  • Podcast 550: PRO TALK With Carpentry Program Instructor Sandy Thistle and Graduate David Abreu
  • Podcast 549: Energy Upgrades, Chimney Inspections, and Questions About a Home You Might Buy
BOOKS, DVDs, & MERCH
Shop the Store
    Buy Now
  • Pretty Good House
    Buy Now
  • 2023 Tool Guide
    Buy Now
    Buy Now
  • Shop the Store
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • Issue 311 - November 2022
    • 7 Steps to a Perfect Exterior Paint Job
    • Options for Smarter Home-Energy Tracking
    • The Fine Homebuilding Interview: James Metoyer
  • Issue 310 - October 2022
    • Choosing a Tile-Leveling System
    • Choosing Between HRVs and ERVs
    • Custom Built-in Cabinets Made Easy
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
