Anyone have any experience with direct vent water heaters which use a PVC pipe to exhaust instead of a metal chimney. Are they worth it, last longer? I need to install quite a few feet of double wall pipe (approx $160 worth) if I go w/ standard gas heater because of no existing chimney to dump into. Thanks. Frank
In this interview, Kimberley talks about the importance of proper training, current concrete trends in the Bay Area, and the history of racist housing policy in San Francisco.
Yes, lots of them around here. If someone orders a house with a high-efficiency (condensing) GFA HVAC; then many builders offer a companion direct vent water heater. They work fine.
We have recently begun to use these units since the Wisconsin Energy Star program requires the installation in new construction. No problems. Disadvantage is when the power goes out, no hot water.
