Is aquabar B an adequate waterbarrier for a shower wall which will be lathed and mortared. Or should 15lb felt be used. Other alternative suggestions are welcome.
Four 2200-sq.-ft. detached homes provide flexible open-plan housing on this Los Angeles block.
There is a recent thread in the Photo Gallery section of how to do a Kerdi shower, there is another discussion somehwere about a new Laticrete product,
Never heard of Aquabar B, but sounds like maybe you need some research before you start one of the absolutest worst things to screw up & fix.
Well, maybe a bad foundation is worse, but shower has to be second.
Joe H
Agreed with the post above.....you need to do A LOT of research on a shower first. I just completed one with the Kerdi system, a guy posted to the photo forum.
I spent about 20 hours just researching waterproofing before I started mine. The Schluter Kerdi system is what I used.
Aquabar B is designed mainly for use under hardwood floors.
It can be used in walls behind tile, but it's not a waterproof membrane, so treat it more like regular #15 felt than visqueen.
Don't use it if the shower will be subjected to heavy use, or if it'll be a steam shower. It's not a vapor barrier, so if you have an exterior wall, you'll still need a vapor barrier there.
This is a "lathed and mortared" shower, so I presume you're using this behind the lathe? I think that'd be fine. Think of it as the drainage plane between the shower and the framing of the house, just like felt would be used.
If you need a vapor barrier then use something else.
Mongo
Lathed & Mortared? they don't sell Durock where you live?
(And I'm assuming you mean metal lath...if it's wood then I am really scratching my head ;-)
I took his mention of "lathe" to mean expanded diamond lathe. Covered with fully floated mud walls. One of many benefits to fully floated mud walls is that the corners can be grouted instead of caulked.I salute him for that, floated walls are well above my level of expertise.
Well beyond mine, too-last time I tried to get that much mud to sick on a wall it laughed & jumped off...
Hadn't thought about the corners-I do recall that you can tweek the mud to fix out of square/plumb framing.
I'd still be Durocking or Schlutering, though.
I did Durock on my walls, conventional PVC membrane pan and mud bed, and then Laticrete 9235 waterproofing over the mud bed and durock. I leak tested the PVC first. It's two separate levels of watertightness, but if water ever gets past the Laticrete membrane, it will hit the PVC and still go down the drain.
I like the Kerdi idea but was a little too hesitant to try it.
The reason for the floated walls is that the existing wall are a bit out of plumb. And Durock won't give me the plumb walls for the tile. Iused to labor for a guy that used aquabar over the green board before he lathed and floated. Tis was also used alot on countertops over ply before lathe and mud. Now I'm secondguessing this technique at least in the shower. Sounds like kerdi is the way to go.
You could sister new plumb studs to the existing out of whack ones to get plumb walls and square corners, then cement board over that. That may be worth the effort regardless of which way you go (Kerdi or not) to make tile layout easier in terms of fewer cuts to make up for wavey walls, etc.
Kerdi is a great material, I have a photo thread over in the photo folder:
Kerdi Pics
If you do Kerdi, remember that the Kerdi will be your vapor barrier, so for the shower you won't need anything (felt/visqueen) behind your cement backer board.
Mongo
I saw your pictures. It looks amazing. Ive never fit durrock that clean. The kerdi sounds and looks very simple, is it really?
Thanks for the kind words.Essentially, Kerdi is simple. It's like hanging wallpaper. You do need to be conscientious in your methods with the detailing, though, and your methods need to take into account the size of tile that will go over it.Plan out your seams/overlaps beforehand as well to make sure they don't end up in akward or inappropriate places.The Kerdi drain is simple to install, but when setting it on a drypack preslope without access underneath, you have one shot to get the installation right as you have to simultaneously glue the drain to the DWV while you mud it into the drypack preslope. Again, not terribly difficult, but attention to detail and anticipation of the steps involved make something that could be difficult a bit less so.With access to the plumbing below, setting the drain in a Kerdi tray or just mudding it in drypack, then coming back later and glueing up the plumbing from underneath is, in my opinion, MUCH easier.It's a very nice product when used correctly. When done correctly, it gives a worry-free shower.Minor point, but the backer board on the walls in the Kerdi thread was Wonderboard, the niches was Hardibacker. No Durock used.I do think Durock is easier to detail than Wonderboard, but I already had the Wonderboard on hand.Thanks again, Mongo
ALWAYS USE A VAPOUR BARRIER BETWEEN THE STUDS AND THE TILE SUBSTRATE THAT IS CODE IN MOST OF THE COUNTRY NOW . USE HARDIEBACKER IF YOU CAN GET IT .
Edited 4/3/2007 9:39 pm ET by bezgrp
