In every issue you'll find...
  • Expert insights on techniques and principles
  • Unbiased tool reviews
  • Step-by-step details to master the job
  • Field-tested advice and know-how
Subscribe Now!
WD40-Can you belive it?
DeepCove | Posted in General Discussion on October 2, 2007 01:56am
After complaining about how I hate using bathroom silicone and how messy it can be, my good friend Roger said I should try spraying it with WD40. He said it makes it workable and allows a smooth application job. My usual application is the standard setup with masking tape on either side of the joint  and smoothing the bead with my finger dipped in soapy water. This can still be messy. And if you don’t get it right the first time, chances are it’ll ripple up with a second pass.
So, today the customer wanted one of those cheapy five piece surrounds put in (which can be a pain in itself, but that’s another story). At the silicone app. I decided to give the WD a shot and sure n
, it worked like a hot damn. Even kept my fingers clean. Now, Roger said that there wasn’t any after effects from using it. I can only hope that’s true. But it is a bathtub/shower stall and repeated washing down will, I’m sure, take away any WD residue.
  1. bldrbill | Oct 02, 2007 02:14am | #1
    It's also used on arthritis.  I have a friend who puts it on his bum knee.
      Sphere | Oct 02, 2007 02:19am | #2
      I put wd on everything 'cept my salad.Spheramid Enterprises Architectural Woodworks
      "If you want something you've never had, do something you've never done"
      1. davidmeiland | Oct 02, 2007 02:21am | #3
        ummm.... which salad would that'n be?
          Sphere | Oct 02, 2007 02:27am | #4
          Shrimp salad , has enough fish oil in it already.Spheramid Enterprises Architectural Woodworks
      JDRHI | Oct 02, 2007 06:43am | #7
      My first aid kit is never without WD40 and duct-tape.
      J. D. ReynoldsHome Improvements
      JeffBuck | Oct 02, 2007 08:20am | #8
      I actually resorted to spraying it in the small of my back for a week last time my back went out.
      didn't do nothing but smell bad ...
      and make the wife laugh at me.
      maybe a back is more of a cracking problem and kness are more of a squeek?
      Jeff    Buck Construction
       Artistry In Carpentry
           Pittsburgh Pa
  2. Jerry18 | Oct 02, 2007 05:56am | #5
    As you already know, water on silicone doesn't work very well (it does fine on caulk though). For silicone try alcohol (rubbing, Johnnie Walker Blue, or whatever). It smooths it out nicely and leaves no residue.
    Jerry
    1. DeepCove | Oct 02, 2007 06:06am | #6
      Use the JW and drink the WD? Never!
  3. Huntdoctor | Oct 02, 2007 11:19pm | #9
    Please explain how you used it.
    1. DeepCove | Oct 03, 2007 01:42am | #10
      On my finger instead of the soapy water.
  4. Jer | Oct 03, 2007 02:00am | #11
    I use the stuff for most anything. I occasionally shine my shaved head with it and use it for room air freshener.
  5. ponytl | Oct 03, 2007 02:09am | #12
    try this...  before working on a car or truck when you know you'll get covered in black grease... spray it on your hands/arms work it under your nails ect...  you will be easy to clean up after...  same thing if you are use'n spray foam...  works great to get poly caulk off your skin... spray it on your leather work boots... shine your good shoes with it too...
    p
  6. bruce22 | Oct 03, 2007 03:06am | #13
    While it has many uses, WD-40 is nothing but kerosene in a spray can. That's genius in marketing.
      JeffBuck | Oct 03, 2007 06:15am | #14
      so then what were the other "39" versions?
           Pittsburgh Pa
Getting Shed Dormer Elevation Right
Drawing a full-scale picture on a scrap of plywood can help get the ridge looking straight.
Get an overview of the process of creating a traditional-style fireplace that burns well and meets current building codes from experienced mason Mike Mehaffey.
  • Keep Craft Alive Podcast: Ep. 19, Jesse Neumann, Arborist
  • FHB Podcast: Special Edition With Neil Freidberg of Louisiana Pacific and Kyle Stumpenhorst of RR Buildings
  • DeWalt Recalls 12-in. Sliding Compound Miter Saws
  • Podcast 483: Recalled Electrical Panels, Drainage Behind Brick, and Lazy Additions
BOOKS, DVDs, & MERCH
Shop the Store
  • Pretty Good House
    Buy Now
  • Outdoor Projects
    Buy Now
    Buy Now
  • 2021 Fine Homebuilding Archive
    Buy Now
  • Shop the Store
  • Issue 309 - Aug/Sept
    • 10 Steps to Install Crown Molding on Cabinets
    • How to Get Sturdy Walls Without OSB
    • Choosing the Right Construction Tape for the Job
  • Issue 308 - July 2022
    • Pretty Good House Book Excerpt: Copper Farmhouse
    • 10 Dos and Don'ts for Electric In-Floor Heat
    • A Sturdy Rail for Outdoor Stairs
  • Issue 307 - June 2022
    • How to Raise a Post-Frame Home
    • Trimming Deck Stairs
    • Evolving an Energy-Efficient Envelope
  • Issue 306 - April/May 2022
    • Framing Stairs to an Out-of-Level Landing
    • Building a Zero-Energy Home for Less
    • Good-Looking and Long-Lasting Traditional Gutters
  • Issue 305 - Feb/March 2022
    • The Steady Surge in Residential Solar
    • The Fine Homebuilding Interview: William B. Rose
    • How Good Is Your Air Barrier?
  • twitter
Taunton Network
  • Copyright
  • Do not sell my information
© 2022 The Taunton Press, Inc. All rights reserved.
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
