Weatherproof above basement garage
asummers | Posted in General Discussion on August 5, 2020 08:55am
Hello. Has anyone had a condition where there is a basement below a covered open porch? What is wanted is a 24’x24′ basement garage with a covered porch on top of it. So, I am wondering about proper water proofing on the roof/floor and the best material to construct the roof/floor out of. My first thoughts are concrete planks spanning the 24′ with a rubber membrane then a type of floating deck or maybe an adhered outdoor tile. Any advice greatly needed. Thanks.
  1. Frankie | Aug 05, 2020 11:29am | #1
    Do you want clear span? This is the most expensive solution.
    If you can accept posts, then 4" concrete on a metal deck.
    You're going to need an engineer. This is not a DYI/ wing-it project. The engineer can provide 2-3 preliminary solutions to assign cost and design priorities.
    At grain may be needed. That's a lot of runoff.
    For waterproofing, Laticrete has a spec for what's involved:
    https://cdn.laticrete.com/~/media/product-documents/product-data-sheets/lds2900_plaza-deck-system.ashx?vs=1&d=20171212T164509Z
    Frankie
  2. jlyda | Aug 05, 2020 03:32pm | #2
    Depends on how much $ you want to spend, your expectation of how long you want before repairs/maintenance issues arise and if the garage below is climate controlled. A lot of different ways it can be handled. The simplest/most affordable would be to build a wood frame flat roof (1/12 pitch) roof above the garage and install a floating deck above it or a better option a deck built above the flat roof.
    If you want something that is maintenance free and will last the life of the home. I would install a hollow core slab above garage. Grout the seams of slabs as usual. A layer of geo textile fabric on that. Then a layer of EPDM. Followed by another layer of geo textile fabric. Finally, a poured slab on top of that with 1/4” per foot slope. Can apply any finish you choose over the concrete or leave as is.
Best Deck for a Steel Roof
For a metal roof, install solid decking such as OSB or plywood.
  • Use a Press Tool for Plumbing Connections
  • Remodeling Around Electrical Panels
  • Podcast 567: Soundproofing, Garage Doors, and Rotted Balconies
  • Podcast 567: Members-only Aftershow — Andrew Zoellner’s House
BOOKS, DVDs, & MERCH
Shop the Store
    Buy Now
    Buy Now
  • Pretty Good House
    Buy Now
  • 2023 Tool Guide
    Buy Now
  • Shop the Store
  • Issue 315 - June 2023
    • How to Craft a Copper Roof
    • 5 Lessons from Building in a Cold Climate
    • The Advantages of Cellular PVC Siding
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • Issue 311 - November 2022
    • 7 Steps to a Perfect Exterior Paint Job
    • Options for Smarter Home-Energy Tracking
    • The Fine Homebuilding Interview: James Metoyer
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
