In every issue you'll find...
  • Expert insights on techniques and principles
  • Unbiased tool reviews
  • Step-by-step details to master the job
  • Field-tested advice and know-how
Subscribe Now!
Weep Holes
Hackinatit | Posted in Construction Techniques on March 8, 2007 08:32am
I see evidence of water retention in the airspace above the 12″ brick ledge and 8″ block course behind the brick veneer.
Would you add weep holes above and below (protected) grade in brick veneer to aid drainage?
Troy Sprout
Socialism in general has a record of failure so blatant that only an intellectual could ignore or evade it.”
— Thomas Sowell
  1. frenchy | Mar 08, 2007 10:16pm | #1
    CAREFULLY HAMMER DRILLJUST A TAD DEEPER THAN THE THICKNESS OF THE BRICK. i'D USE ABOUT 1/4 INCH BIT
       About 8 inches apart or so.. at he lowest point you can..  then because you don't want critters to make it thier new playground stuff either bronze wool or  some form of plastic mesh in there
    1. Hackinatit | Mar 09, 2007 01:35am | #3
      Thanks!
      I used a 3/8" and punched them carefully, at an upward angle, below the window ledge and above finished grade.
      I just don't feel good about holes below grade...
      so I guess I answered my own inquiryTroy Sprout
      Socialism in general has a record of failure so blatant that only an intellectual could ignore or evade it."-- Thomas Sowell
  2. DaveRicheson | Mar 09, 2007 12:30am | #2
    Is the brick laid on a flashing membrain?
    Frenchy is right, but if there is flashing behind the brick (should be), be carefull you don't puncture it. That would make matters worse.
    Dave
    1. Hackinatit | Mar 09, 2007 01:44am | #4
      Ain't no flashing on this house.... 'cept where I've been.
      This is below both grade and first floor framing by several bricks. I guess they felt ok with no flashing. :(Troy Sprout
Industry-First Cordless Rebar Cutter and Bender
A brushless motor and 36v batteries power Metabo HPT’s cordless rebar bender and cutter.
  • Podcast 486: PRO TALK With Builder and Remodeler Mason Lord of HVP in Kent, CT
  • Get Stunning Views With Folding Glass Doors
  • Keep Craft Alive Podcast: Episode 20, Ian Schwandt, TDS Custom Construction
  • Step-by-Step Install Prehung Exterior Doors
BOOKS, DVDs, & MERCH
Shop the Store
  • 2021 Fine Homebuilding Archive
    Buy Now
  • Pretty Good House
    Buy Now
    Buy Now
  • Outdoor Projects
    Buy Now
  • Shop the Store
  • Issue 309 - Aug/Sept
    • 10 Steps to Install Crown Molding on Cabinets
    • How to Get Sturdy Walls Without OSB
    • Choosing the Right Construction Tape for the Job
  • Issue 308 - July 2022
    • Pretty Good House Book Excerpt: Copper Farmhouse
    • 10 Dos and Don'ts for Electric In-Floor Heat
    • A Sturdy Rail for Outdoor Stairs
  • Issue 307 - June 2022
    • How to Raise a Post-Frame Home
    • Trimming Deck Stairs
    • Evolving an Energy-Efficient Envelope
  • Issue 306 - April/May 2022
    • Framing Stairs to an Out-of-Level Landing
    • Building a Zero-Energy Home for Less
    • Good-Looking and Long-Lasting Traditional Gutters
  • Issue 305 - Feb/March 2022
    • The Steady Surge in Residential Solar
    • The Fine Homebuilding Interview: William B. Rose
    • How Good Is Your Air Barrier?
  • twitter
Taunton Network
  • Copyright
  • Do not sell my information
© 2022 The Taunton Press, Inc. All rights reserved.
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
