In every issue you'll find...
  • Expert insights on techniques and principles
  • Unbiased tool reviews
  • Step-by-step details to master the job
  • Field-tested advice and know-how
Subscribe Now!
Western NY plumbing
jrnbj | Posted in General Discussion on July 1, 2006 08:07am
I learned what I know about plumbing in the DC Metro area, but now I’m in Buffalo, & things are different here.
Every house has, in the front yard, a vent & trap assembly on the main sanitary line. I never saw this in DC….I don’t know what the reasoning is for it, but I do know I see them being snaked there often, and also being dug up & re-piped….I suspect the vent pipes tend to let in debris, and tend to heave some in the winters.
I’ve got 2 floor drains in my basement. One is 3′ from the sump pump, has 1 clay drain tile coming in, and one going out straight to the sump pit….it’s at the low spot in the floor, it pre-dates the sump, and I’m thinking it may have been connected to the main line prior to the installation of the sump pump…though it seems to be mostly mud at the bottom, and I cant feel an old plugged hub anywhere.
The second floor drain is about 6′ from the first, and right next to a 3′ main from the adjacent wash tub and the kitchen above. It doesn’t drain at all. (I’ll have a later post on how I came to find this out). My first thought was that the previous HO had plugged it (the local plumbing inspector wants basement drains run to the sump pit, because otherwise you get groundwater into the sanitary sewers, instead of into the separate storm sewer-which, if it were raining in your basement, I might agree with! ).
Yesterday I sucked the standing water out of the floor drain, (got that nice, nasty old drain black smelly gunk into the wet-vac). Then I got out my big (but unfortunately, manual) snake out & went at it. There’s no trap, and the snake turns the corner at the bottom (with the water out, I could see a nice sweep elbow down there) and goes about 2 feet before it hits what seems to be mostly grey clay.
So. this drain doesn’t seem to be connected to the kitchen drain…or to the sump pit…and I’m wondering what it does go to, & debating renting a proper sewer snake & going at it.
I also wonder why there’s no trap on the floor drain. I’m pretty sure the houses here were built with separate downspout drains to the street storm sewer, but the local practice is to not allow there use anymore, & either run to grade, or get what they call a “bubbler”, which is a new PVC line, run to the curb, & then tee-d down into the storm sewer & up to grade. I don’t think the floor drain would have been connected to that…too far below grade.
Any plumbers out there got any insights for me?
Using Liquid Flash at a Wall-to-Foundation Connection
Brian Pontolilo demonstrates how to air-seal where the concrete foundation, mudsill, and ZIP System sheathing all meet.
  • Get Stunning Views With Folding Glass Doors
  • Keep Craft Alive Podcast: Episode 20, Ian Schwandt, TDS Custom Construction
  • Installing Prehung Exterior Doors
  • Podcast 485: Air-Sealing a Mobile Home, Owner/Builder Tests, and Ready-to-Tile Shower Bases
BOOKS, DVDs, & MERCH
Shop the Store
    Buy Now
  • 2021 Fine Homebuilding Archive
    Buy Now
  • Outdoor Projects
    Buy Now
  • Pretty Good House
    Buy Now
  • Shop the Store
  • Issue 309 - Aug/Sept
    • 10 Steps to Install Crown Molding on Cabinets
    • How to Get Sturdy Walls Without OSB
    • Choosing the Right Construction Tape for the Job
  • Issue 308 - July 2022
    • Pretty Good House Book Excerpt: Copper Farmhouse
    • 10 Dos and Don'ts for Electric In-Floor Heat
    • A Sturdy Rail for Outdoor Stairs
  • Issue 307 - June 2022
    • How to Raise a Post-Frame Home
    • Trimming Deck Stairs
    • Evolving an Energy-Efficient Envelope
  • Issue 306 - April/May 2022
    • Framing Stairs to an Out-of-Level Landing
    • Building a Zero-Energy Home for Less
    • Good-Looking and Long-Lasting Traditional Gutters
  • Issue 305 - Feb/March 2022
    • The Steady Surge in Residential Solar
    • The Fine Homebuilding Interview: William B. Rose
    • How Good Is Your Air Barrier?
  • twitter
Taunton Network
  • Copyright
  • Do not sell my information
© 2022 The Taunton Press, Inc. All rights reserved.
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
