What makes a good faucet?
MnDel | Posted in General Discussion on December 2, 2006 10:57am
We will be installing a roman tub faucet (deck mounted). I also want the hand held shower attachment with it.
I would like to know what are important features to look for – ie. quality mechanism and ease of installation. (We, as homeowners, will try to install this ourselves, if possible.)
Any suggestions of quality brands, makes and models would be very helpful (if that is allowed on this forum). I don’t want anything extra fancy or too pricey – just good function.
  1. edwardh1 | Dec 02, 2006 11:10pm | #1
    does not rust
    avoid brass regardless of the mfg claims
    1. plumbbill | Dec 02, 2006 11:15pm | #3
      When you say "brass" I'm assuming that you mean the finish , not the base material.“It so happens that everything that is stupid is not unconstitutional.” —Supreme Court Justice Antonin Scalia
      1. edwardh1 | Dec 02, 2006 11:20pm | #4
        yes
  2. plumbbill | Dec 02, 2006 11:14pm | #2
    When it comes to brands opinions are far more likely than facts.
    I'm assuming this is a retrofit, so a 3/4" tub filler will not get all the flow it was made for with 1/2" pipes feeding it.
    Although a 3/4" filler will allow more flow than a 1/2" one will.
    When it comes to tub fillers I want to put as much water in the tub as fast as possible.
    Hand showers are great, look for one that has a pressure actuated diverter that defaults to the spout when the water is shut off.
    If you have a manual diverter you will have to install a backflow device to protect the potable water from the tub water. A vacum breaker or an inline double check will do to meet code requirements.
    OK for brands I like these 3 : Kohler, Grohe, & Delta. All have a good reputation, & as of 5 yrs ago Grohe parts have been easier to get.
    1. MnDel | Dec 02, 2006 11:29pm | #5
      Your ideas are much appreciated.This is new construction, so no plumbing or water lines are installed yet. This will be mounted on the deck of a whirlpool bathtub, so the spout will have to have a pretty good reach.What did the person mean that said "no rust".?
      1. plumbbill | Dec 02, 2006 11:48pm | #6
        Not sure exactly on the no-rust comment, other than make sure there is no iron pipe or fittings or the water will be rusty comming out & will stain any tub.
        Carefull with deck mount fillers & tall lipped tubs there needs to be a 1" air gap between the spout opening & the flood level of the tub.
        I'm just wrapping up the last condo of a 145 unit 42 story condo & this was our building standard for tub filler with hand shower.
        http://www.grohecatalog.com/product/25049/“It so happens that everything that is stupid is not unconstitutional.” —Supreme Court Justice Antonin Scalia
        1. edwardh1 | Dec 03, 2006 01:57am | #7
          no rust means the exterior will not rust.get one that rotates too
          1. MnDel | Dec 03, 2006 02:29am | #8
            Rotating would be great - but who makes that style? I have not found that option anywhere.
          2. rwjiudice | Dec 03, 2006 03:21am | #9
            My home is 9.5 years old. I have both Moen and Delta fixtures. The "brass finish" on both is warrantted for life. I had a minor blemish after 9 years on the Moen. Called the 800#, explained I built the house 9 years ago so had no "paperwork". No problem, had the replacement part in 3 days, no charge.
            Same happened with Delta. Both great!!!!
Behind the Scenes of a Concrete Batch Plant
The batch plant is your partner in getting high-quality concrete on your job site.
Get an overview of the process of creating a traditional-style fireplace that burns well and meets current building codes from experienced mason Mike Mehaffey.
  • Podcast 551: Power Tool Batteries, Building as a Third Career, and High DIY
  • Podcast 551: Members-only Aftershow—Badly-Built Homes
  • Podcast 550: PRO TALK With Carpentry Program Instructor Sandy Thistle and Graduate David Abreu
  • Podcast 549: Energy Upgrades, Chimney Inspections, and Questions About a Home You Might Buy
BOOKS, DVDs, & MERCH
Shop the Store
    Buy Now
    Buy Now
  • 2023 Tool Guide
    Buy Now
  • Pretty Good House
    Buy Now
  • Shop the Store
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • Issue 311 - November 2022
    • 7 Steps to a Perfect Exterior Paint Job
    • Options for Smarter Home-Energy Tracking
    • The Fine Homebuilding Interview: James Metoyer
  • Issue 310 - October 2022
    • Choosing a Tile-Leveling System
    • Choosing Between HRVs and ERVs
    • Custom Built-in Cabinets Made Easy
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
