In every issue you'll find...
  • Expert insights on techniques and principles
  • Unbiased tool reviews
  • Step-by-step details to master the job
  • Field-tested advice and know-how
Subscribe Now!
What size sheathing
| Posted in Construction Techniques on October 1, 2002 06:48am
I have just put up my trusses. And I would like to know what size of  roof sheathing to use. I’m putting on a concrete tile roof. Code says I can use 1/2 inch. But everyone tells me to use 5/8’s So the roof won’t sag.  Will it, and should I use the 5/8’s. Thanks Hat
  1. bill_1010 | Oct 01, 2002 07:37am | #1
    talk with the truss maker.  If designed properly to handle the roofing material and 5/8ths id use 5/8ths.  A few years down the road when you try to sell the house, and the buys notices ripples on that 1/2 inch stuff it will be a downgrade.  Sure you could use 1/2, but i dont think youll be happy in time.   Are you considering OSB sheathing or plywood?  If you use 1/2 OSB, my gut reaction is ripple city.
    1. TimGoins | Oct 01, 2002 08:16am | #2
      I will be using OSB. Hat
      1. JoeH | Oct 01, 2002 08:34am | #3
        Is the tile going on purlins? What's the spacing on the trusses? Joe H
      BossHog | Oct 01, 2002 01:11pm | #5
      The truss company doesn't care what kind of plywood you use - No point asking them about that. The trusses need continuous bracing along the top chord, but almost any thickness of plywood can do that.
      My concern with the trusses is whether or not they were designed for added loads of the concrete tiles.
      As for the thickness of the playwood - Why not ask the tile manufacturer? The're the ones you'll be looking to for a warranty. See what they require, so you don't have any nasty surprises down the road.
      What goes around usually gets dizzy and falls over.
      1. TimGoins | Oct 01, 2002 07:33pm | #6
        They are 24 inch o.c. And they are rated for concrete tile. That is what I had them made for. I think that is a good idea to call the tile supplier. They would know. Thanks Hat
  2. FrankB89 | Oct 01, 2002 08:39am | #4
    If you're using OSB and putting on concrete tiles, it might be worth jumping up to 3/4" sheathing.  You didn't mention the layout of your trusses so I'm assuming the worst at 24" in which case 1/2" is totally out of the question.  As other posters have said, you'll get ripple city.  The difference in cost between 5/8" and 3/4" shouldn't be a deal killer and getting 3/4" OSB up on the roof won't be much different than 5/8" plywood.
    Always remember that codes are MINIMUM standards and "doing it right" often means exceeding code if your objective is a good, solid building.
    You might want to verify your structural requirements for supporting the concrete tile roof from the roofing manufacturer.  I'm not sure exactly what you're dealing with, but I've framed ahead of a couple of traditional Spanish tile roofs and the roof loading is much higher than for other materials.
Infill Addition to a Classic Farmhouse
By connecting the home to the detached garage, the architects of this hillside home made space for a home office and guest area.
Get an overview of the process of creating a traditional-style fireplace that burns well and meets current building codes from experienced mason Mike Mehaffey.
  • How to Frame an I-Joist Roof
  • Designer Kitchen Cabinets on a Budget
  • Podcast 459: Leaky Attic Stairs, Right-Sizing Heat Pumps, and Vapor Barriers in Dirt Crawlspaces
  • Linda Reeder: Architect, Professor, and Author
Justin Fink Deck Building Course announcement
Sign Up See all newsletters
BOOKS, DVDs, & MERCH
Shop the Store
  • Tool Guide 2022
    Buy Now
    Buy Now
  • 2021 Fine Homebuilding Archive
    Buy Now
  • Outdoor Projects
    Buy Now
  • Shop the Store
  • Issue 307 - June 2022
    • How to Raise a Post-Frame Home
    • Trimming Deck Stairs
    • Evolving an Energy-Efficient Envelope
  • Issue 306 - April/May 2022
    • Framing Stairs to an Out-of-Level Landing
    • Building a Zero-Energy Home for Less
    • Good-Looking and Long-Lasting Traditional Gutters
  • Issue 305 - Feb/March 2022
    • The Steady Surge in Residential Solar
    • The Fine Homebuilding Interview: William B. Rose
    • How Good Is Your Air Barrier?
  • Issue 304 - Dec 2021/Jan 2022
    • Why You Need Blower-Door Testing
    • Passive-House Standards for Everyone
    • Window Replacement With a Side of Rot Repair
  • Issue 303 - November 2021
    • Compact Cordless Miter Saws
    • Maximize Space with Thoughtful Built-Ins
    • 10 Essentials for Quality Trim Carpentry
  • twitter
Sign Up
Taunton Network
  • Copyright
  • Do not sell my information
© 2022 The Taunton Press, Inc. All rights reserved.
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
Start your subscription today and save up to set_percent%
