Hello! I have read the thread on adjusting floor elevations between different rooms while trying to tile a bathroom floor. I also have the same problem. The distance I can live with from top of floor joist to finished surface is 1 5/8″
My bathroom is 10′ x 10′ that flexes when you jump on it (joists underneath are long span, on 16″ centers in a 100 yr old balloon frame structure.) I have sistered all joists with new lumber and added cross bracing to stiffen things up a bit – but it still moves maybe 1/16 – to 3/32″ when a 200 lb man jumps up and down on it. ( I should have sistered with 1/4″ steel – then it wouldn’t have flexed! 🙂
I would like to lay down either a 1″ mosaic tile floor or 6″ marble tiles. My concern is having tiles pop because of floor flexion. I only want to do this job once. I’m getting too old and the wrists aren’t what they once were.
I will take out the subfloor (again) and install 3/4 ply between joists. I can put another layer of 5/4 ply on top of this. I am then left with 1/4 to finished height. Tiles or marble will both be about 1/4″ over 1/8 thinset. But will this system flex and pop the tiles?
Or – would I be better off using some type of concrete floor system?
Several months ago, there was a FHB article where the author laid a thin mud bed by using expanded metal lath over roofing felt and stapled to 3/4 subfloor and troweled over with concrete / thinset. Again, raising the floor height with moor subflooring was not possible. What if I used this system, but made the concrete reinforced floor a full 1 1/4″ thick. Is this thick enough to stop flexion in the subfloor, or will it still crack?
Am i better off starting over ( I still have no finished floor down) and putting in steel sisters to stop flexion?
I just don’t want to do it over again in 10 years. How did those old timers do it? I have seen many examples of entry foyers with beautiful 1/2″ mosaic tiles – in wood construction houses.
Thanks for your help!
Robert
Rob,
I wouldn't go any thinner than an inch with a mud floor and then use reinforcing and an additive to strengthen the mix.
Another alternative ( which I did in my own house) seeing as you are prepared to pull up the existing floor is to install your ply between the joists ( keeping it down a good 2 or 3 inches to form a floor for a pour right amongst and over the joists ( again reinforce etc ), this should give you a good stiff floor to tile onto.
Rgards
Mark
*Wow, Robb, you really want a "tight" floor. You ask some interesting questions, but I believe you are somewhat misleading yourself. I think with all the work you are considering, you should be concerned with the dead load of the subfloor. Deflection of the floor of 1/360 of the span is standard. 3/32" is not in excess of that, so beefing up the floor to remove even that amount of deflection is not warranted.As Mark has stated, a cement mortar bed of 1" T is the minimum. I would second his proposed method of building your subfloor. And, I wouldn't worry about all the other stuff.I am concerned about your intentions of using only 1/8" thinset to set tile or marble. I suppose if the floor were really, really flat, you could get away with using such a thin layer of thinset, but I suggest a minimum 3/16, preferrably 1/4". For marble, I use a 1/4 x 1/4" square notch trowel and backbutter (skimcoat) each tile. Especially for polished stone.For what you want, I would suggest you disregard the installation method of troweling a thin coat over metal lath. You want something thicker.
*... I'm even less industrious, and would consider using something other than tile! How about a solid sheet of 1 1/2" granite? (Just kidding.) Terrazzo might be pretty cool. A nice wood floor with proper moisture protection? Or set stones in construction adhesive for a slightly flexible connection? Or Pergo? And no jumping in the bathroom.Mark's idea is pretty clever. But the weight? Is the bathroom at midspan?
Hi. Thanks to everyone for their responses.
Yeah - I got to think about the dead load in that room. The floor joists are only 2X8 and they span 14' . And of course the bathroom is at midspan. (Yeah I know, the max span for that size joist - Doug Fir - is LT 12'. But somehow, 100 yrs ago, they didn't know that.
"Hey, and you want to add 13 psf on top of that - plus an old ball and claw bath tub filled with water with your 200 pounds floating in it??!....See you in the dining room on your way to the basement!" :-)
Got to think this one over some more. Maybe I'll tear out that sagging ceiling underneath and sister on some 1/4 " steel to those joists. How badly do I want that floor?
I saw the greatest floor in Jersey City, NJ last week. Old tesserae marble chips with a Greek pattern around the perimeter. Got to have it.
That's what I was hoping to put in on top of the mud bed. But I might just settle for a Pergo floor and be done with the weight and the worrying.
Hey! What about 3/4 T&G plywood, glued and screwed, covered with 1/2" Wonderboard, with marble tesserae on thinset. That would only be about 4 psf finished. Think that would hold up without cracking?
No. Not if you can't eliminate the bounce.
*I admire your stubbornness! But i bet you could put all the time this will take into something else in your house that really needs it. There's always something.
Hello! I have read the thread on adjusting floor elevations between different rooms while trying to tile a bathroom floor. I also have the same problem. The distance I can live with from top of floor joist to finished surface is 1 5/8"
My bathroom is 10' x 10' that flexes when you jump on it (joists underneath are long span, on 16" centers in a 100 yr old balloon frame structure.) I have sistered all joists with new lumber and added cross bracing to stiffen things up a bit - but it still moves maybe 1/16 - to 3/32" when a 200 lb man jumps up and down on it. ( I should have sistered with 1/4" steel - then it wouldn't have flexed! :-)
I would like to lay down either a 1" mosaic tile floor or 6" marble tiles. My concern is having tiles pop because of floor flexion. I only want to do this job once. I'm getting too old and the wrists aren't what they once were.
I will take out the subfloor (again) and install 3/4 ply between joists. I can put another layer of 5/4 ply on top of this. I am then left with 1/4 to finished height. Tiles or marble will both be about 1/4" over 1/8 thinset. But will this system flex and pop the tiles?
Or - would I be better off using some type of concrete floor system?
Several months ago, there was a FHB article where the author laid a thin mud bed by using expanded metal lath over roofing felt and stapled to 3/4 subfloor and troweled over with concrete / thinset. Again, raising the floor height with moor subflooring was not possible. What if I used this system, but made the concrete reinforced floor a full 1 1/4" thick. Is this thick enough to stop flexion in the subfloor, or will it still crack?
I just don't want to do it over again in 10 years. How did those old timers do it? I have seen many examples of entry foyers with beautiful 1/2" mosaic tiles - in wood construction houses.
Robert
