Title pretty much says it all. I don’t do it much, but now have to hang a bunch of drywall, and I deserve a new tool. So assuming RotoZips are the tool to have for this, which model?
Their website is not very helpful. The model numbers change, but nothing in the tool spec’s changes. And is there a better tool for cutting drywall around doors, windows, and boxes?
And how exactly do you handle elec. boxes? Just mark the center, hang the rock, and cut away? The bit won’t chew through the plastic box? And is there a direction to move the tool – counter-clockwise for example?
It seemed like such a simple question at first – which RotoZip…..
Go to a drywall supply center, not HD or Lowes, and see what models they are displaying. They service the pros, so you should get a good gauge of what to get there.
Thanks paperhanger. That's good idea. Any other advice - like tips for the user?
I start at the center of the box move to the right, jump the side of the box to the outside edge, go around the box counterclockwise while keeping light pressure on the panel. Window and door openings you go clockwise. For a beginner the window and door bit may work better because it doesnt snap off as easily. Use the bit with the guide tip. It can still eat a plastic box if you dont move at a steady pace. Window bit will leave too big a gap around boxes so use 1/8 inch guidepoint bit. Practice on some scrap. Get the cheapest model if its only for drywall. Ive seen guys use all kinds of models from stripped down routers to roto zips. Ive got an old rotozip about twice the size of the new ones. Must be 15 years old. Cant kill it. Bases on the new ones are much better. Use glasses, the bits snap easily and the dust is brutal.
Thanks ccal,
Those are the tips I was looking for.
I have a rotozip rebel, it has two led headlights. They are very handy if you're working in a corner, like removing caulk from the corner of a bathtub, on in a dark area. But otherwise almost any rotozip will work. The dremels are too light duty and will not last. Be sure to use the drywall bit. It has a small area on the end that is smooth and designed to ride against the j-box. If you use a regular bit, it will cut right through the box.
Thanks FastEddie,
The tip on the drywall bit surely saved the first box I would have attempted to cut around.
roto zips are great. go clockwize. any model will do. pratice first, they will get away from you. note. the collar lock will always break on you, no big deal a 16 penny nail works fine, just slip in the hole to unlock the collar nut.
