will a 2×6 box stay straight
dbtodd | Posted in General Discussion on February 12, 2006 02:40am
will a box made of standard 2×6 stay straight.  my plan is to use a 2×6 constructed box about 60 inches tall  cover it in stone tile and used as a newel post
  1. davidmeiland | Feb 12, 2006 03:15am | #1
    Probably not the best way to do a tile column. I would make it out of 3/4" or 1-1/8" plywood instead, biscuits and screws for the joints, then wrap it in tile backer board using backer board screws.
    EricPaulson | Feb 12, 2006 03:49am | #2
    Depends on what the 2x6 species is.
    [email protected]
  3. Notchman | Feb 12, 2006 04:07am | #3
    You might also consider building your post column of concrete half-blocks on a concrete footing.
    Place a couple #4 bars in the footing, slip the block over them, mortar the joints, fill the cores.
    May sound like a bit of work, but it really won't be and it's a very simple masonry/block-laying project that will give you an excellent surface for your tile.
  4. IdahoDon | Feb 12, 2006 05:39am | #4
    If framing lumber hasn't had time to dry it's going to shrink a great deal--and twist, and cup, etc.  Not good things to have happen under tile.
    Plywood gets my vote.
