In every issue you'll find...
  • Expert insights on techniques and principles
  • Unbiased tool reviews
  • Step-by-step details to master the job
  • Field-tested advice and know-how
Subscribe Now!
Window jams potrude beyond drywall.
Philios | Posted in General Discussion on October 17, 2005 12:49pm
Hello,
I have been trying to trim out some windows which the jams extend beyond the drywall in some cases upto a 1/4 inch. I have been hand planing or rabeting the trim depending on how consistent the patrusion beyond the drywall is. I am thinking of getting a power hand planer to bring the jams level to the drywall, however, I have never used one of these and I am a little worried it will tear up the corners on the jams. Does anyone use this method? and if so what kind of planer do you use.
Thanks in advance.
  1. tyke | Oct 17, 2005 01:08am | #1
    flush cutting router bit with bearing on the end works well. use a router or if not enough room use roto zip possibly. 1/4" bit fits it fine.
    tyke
    Just another day in paradise
  2. GregDi | Oct 17, 2005 01:33am | #2
    I usually use power planer for that sitution.
    There is a knack to learning how to use one, but the feel is similar to a really sharp hand plane.
    Practice on some scraps first.
  3. piko | Oct 17, 2005 01:41am | #3
    As per GregDi - practise. When you approach the internal corners it helps that any tearout should be on the outer edges - ergo, work from centre to the o/s. Keep the heel of the plane at an angle to the jambs, too, so that  the blade takes only a little piece out of the grain of the adjoining piece, rather than a big 'bite' of grain at one pass.
    All the best...
    To those who know - this may be obvious. To those who don't - I hope I've helped.
  4. Bikerdad | Oct 17, 2005 03:52am | #4
    I have had that same problem many times in trimming out windows.The first thing I do is go to the truck and get my really big deep throat Jorgensen clamps.Open the window and put a block on the outside away from the window and put another on the protruding ext jambs...crank until just past flush and nail the ext jambs into the liners..don't forget to shim behind the nails.This trick also works for the opposite problem...ext jambs not reaching the drywall..just do the opposite....later curse out the dope who installed the window..if he understands english..
    1. slykarma | Oct 17, 2005 08:20am | #5
      And what do you do on a fixed light window?
      Do you repair the cracked exterior stucco yourself or pretend it was like that before you got there?Lignum est bonum.
      1. Bikerdad | Oct 17, 2005 01:06pm | #6
        fixed lite window...plane down ext jambs..send builder an additional charge for fixing someonem elses screw up (that cost you money )
        stucco...what makes you even think I would not have thought about that first ! Obviously I would not want to damage the stucco so if the window did not relent easily I would just plane down ext jambs..and send builder a  bill for additional work... I'm guessing here you have experience damaging stuccom "skykarma" A little more thinking ahead and a few more years of experience would help you out...I am not claiming to be an expert on everything here,just my trade,and I'm always looking for new and better ways to do things...I love to learn..Is'nt that the reason for this discussion board ????
        ...If I want any crap out of you I'll squeeze your head....
        1. slykarma | Oct 17, 2005 03:15pm | #8
          Man I gotta stop posting late at night.  Reading my previous post I can see I was pretty snotty. My apologies.
          My choice of technique depends on the state of finished floors. If dust and debris are going to  be an issue, I plane the jambs. But it's generally quicker and slicker to use a router if mess isn't an issue yet.Lignum est bonum.
          1. Bikerdad | Oct 18, 2005 01:37am | #10
            No offense taken Dude,If I had answered you now after the day I have had We'd be really getting into it...freaking banks and lawyers...another good bashing session for another day...I'll only say it should'nt take 4 months to close on a freaking construction loan......
            ..I'd rather have a bottle in front of me than a prefrontal lobotomy.......
    2. Philios | Oct 17, 2005 05:08pm | #9
      Thanks very much for all the responses, it is great to have the benefit of the experience out there.
      Phil
    jocobe | Oct 17, 2005 03:08pm | #7
    It's kinda hard to explain, but I'll try.
    I take a laminate trimmer and put a mortise bit in it. I then take a small piece of wood and contact cement it to the base. The edge of the wood goes accross the diameter, so you'll need to cut a half circle where the bit is. Then adjust the depth of the bit to be flush with the face of the wood. Then place the wood base flat on the drywall and run the bit into the protruding jamb. It will cut it off perfectly flush and not tear out.
DeWalt Recalls 12-in. Sliding Compound Miter Saws
Purchasers of certain models should stop using the saw immediately and contact DeWalt to receive a free repair kit.
  • Podcast 486: PRO TALK With Builder and Remodeler Mason Lord of HVP in Kent, CT
  • Get Stunning Views With Folding Glass Doors
  • Keep Craft Alive Podcast: Episode 20, Ian Schwandt, TDS Custom Construction
  • Step-by-Step Install Prehung Exterior Doors
BOOKS, DVDs, & MERCH
Shop the Store
    Buy Now
  • 2021 Fine Homebuilding Archive
    Buy Now
  • Pretty Good House
    Buy Now
  • Outdoor Projects
    Buy Now
  • Shop the Store
  • Issue 309 - Aug/Sept
    • 10 Steps to Install Crown Molding on Cabinets
    • How to Get Sturdy Walls Without OSB
    • Choosing the Right Construction Tape for the Job
  • Issue 308 - July 2022
    • Pretty Good House Book Excerpt: Copper Farmhouse
    • 10 Dos and Don'ts for Electric In-Floor Heat
    • A Sturdy Rail for Outdoor Stairs
  • Issue 307 - June 2022
    • How to Raise a Post-Frame Home
    • Trimming Deck Stairs
    • Evolving an Energy-Efficient Envelope
  • Issue 306 - April/May 2022
    • Framing Stairs to an Out-of-Level Landing
    • Building a Zero-Energy Home for Less
    • Good-Looking and Long-Lasting Traditional Gutters
  • Issue 305 - Feb/March 2022
    • The Steady Surge in Residential Solar
    • The Fine Homebuilding Interview: William B. Rose
    • How Good Is Your Air Barrier?
  • twitter
Taunton Network
  • Copyright
  • Do not sell my information
© 2022 The Taunton Press, Inc. All rights reserved.
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
