winter ready sump pump?
k1c | Posted in General Discussion on April 17, 2007 02:28am
I rigged a sump-pit which is outside.  Indoor sump pump would’ve been objectionable.  I’ve been using Rule sump pump, but they don’t make it any more, just for pools and boats.  Rule pumps survived at least 3 winters on average.
I found Ridgid diaphragm switch pump, Little Giant pressure switch (diaphragm) pump, and Water Ace electronic switch pump.  Little Giant has the best review but does anybody know if diaphragm will survive the freeze?  Rule was electronic as well, but does anybody know the quality of Water Ace?  Thank you in advance.
  1. rez | Apr 17, 2007 07:54pm | #1
    Greetings k1c,
    This post, in response to your question, will bump the thread through the 'recent discussion' listing again which will increase it's viewing.
    Perhaps it will catch someone's attention that can help you with advice.
    Cheers
    Parolee # 53804
    1. k1c | Apr 17, 2007 08:57pm | #2
      Thank you for your help.  After more research, I found a device called Flood Free Electronic level control.  It seems to be on-off switch that a pump, any pump, can plug into, and it has wire sensors for water level.  Seems like this is the way for me since I don't have to worry about submerged pump in winter.  One reputable maker said that housing can crack if left in ice.  If this device is reliable, I would use a utility pump installed outside of the pit.  So I was wondering, did anybody use this device?  Is it reliable?  Thank you in advance.
        Jeff_Clarke | Apr 17, 2007 09:23pm | #3
        Well, I have an outside sump in the making - haven't gone through one winter yet.   I was planning to insulate the underside of the lid and allow the fact that it's very unlikely to freeze 5' below grade, right?  What is your location?
        Pump is Zoeller M267 effluent type - 2" discharge
        1. k1c | Apr 19, 2007 08:02am | #4
          I am in New Jersey.  I dug the pit only down to the footing, which was about 3 feet.  I'm not sure how a pit can be insulated from the top down.  I am guessing that you are hoping the bottom will not freeze.  It seems like the pit and the cover have to be super insulated to depend on the ground temperature.  The Rule sump pump did survive a few winters.  After saying Rule doesn't make the pumps anymore, I checked their website just on a off chance, and they have pumps again.  But for me, they don't have a distributor close enough and that decided for me to go with a regular sump pump, such as Zoeller or Liberty, and just remove them in winter.  Since the pit is outside, I don't have to worry about basement flooding.  If the ground gets saturated, I just have to return the pump.  This pit was to keep the basement slab as dry as possible, never to deal with any water coming in.
          The electronic flood level sensor seemed like a good idea until I remembered that outside (of the pit) utility pump will not work without prime.  One company suggested a diaphragm pump, which can start pumping dry, but diaphragm pumps have small capacity and probably the diaphragm will not survive freezing.  Good luck with your project.
          1. DanH | Apr 19, 2007 01:35pm | #7
            New Jersey? You just need to insulate the top of the pit well and the pump won't freeze.
      2. DanH | Apr 19, 2007 01:32pm | #5
        I've used one of those controls (maybe a different brand) and they work well.But a utility pump has water in its impeller chamber and will crack if it freezes. Better to have the pump in the pit and insulate the top of the pit.
      3. DanH | Apr 19, 2007 01:33pm | #6
        Where do you live, by the way? How cold does it get?
    MarkH | Apr 19, 2007 01:54pm | #8
    Get a deicing heater from Tractor Supply or a similar place.  They keep water from freezing, and are thermostatically controlled.  They do not heat much more than freezing, so they have a relatively low power consumption.  There are different versions available.
    http://mytscstore.com/detail.asp?pcID=8&paID=1039&sonID=213&page=1&productID=15553&zz=45420
    Edited 4/19/2007 6:58 am ET by MarkH
    Jeff_Clarke | Apr 19, 2007 01:59pm | #9
    I am in central New Jersey.
    The bottom of my exterior sump (Zoeller effluent pump) is around - 5 feet below grade.
    The frost depth in our area is - 36" so you may have some concerns.  Below frost depth the ground rarely gets below 50 degrees.
    What about taking the lid and fastening a round plastic trash can or pail to it with a hole in the bottom?   Then fill with expanding foam - instant insulated plug.
    Edited 4/19/2007 6:59 am ET by Jeff_Clarke
    1. k1c | Apr 24, 2007 06:57am | #10
      Thank you and the others for ideas.  The plumbing store also mentioned the possibility of ice cracking the pump body.  My concern about the insulated sump pit comes from shallow footing insulation and how much such footing has to be insulated.  The discharge hose is also open to ground and it seems too expensive to experiment with a new pump at this point.  Heating the water sounds interesting.  I might even try my old fish tank heater.  Thank you all again.
Fine Homebuilding – April/May 2023, Issue #314
Find online articles on options for countertops, wood-boring bits, ductless heat pumps, tighter miters, fences, and much more.
  • Podcast 549: Energy Upgrades, Chimney Inspections, and Questions About a Home You Might Buy
  • Podcast 549: Members-only Aftershow—Patios vs. Decks
  • Podcast 548: PRO TALK With Design/Build Operations Manager Jessica Bishop-Smyser
  • Strategies for Venting a Roof Valley
BOOKS, DVDs, & MERCH
Shop the Store
  • 2023 Tool Guide
    Buy Now
  • Pretty Good House
    Buy Now
    Buy Now
    Buy Now
  • Shop the Store
  • Issue 314 - April/May 2023
    • 7 Options for Countertops
    • Tool Test: Wood-Boring Bits
  • Issue 313 - Feb/March 2023
    • Practical System for a Seismic Retrofit
    • Fine Homebuilding Issue #313 Online Highlights
  • Issue 312 - Dec 2022/Jan 2023
    • Tool Test: Cordless Tablesaws
    • Gray-Water System for a Sustainable Home
    • Insulate a Cape Roof to Avoid Ice Dams
  • Issue 311 - November 2022
    • 7 Steps to a Perfect Exterior Paint Job
    • Options for Smarter Home-Energy Tracking
    • The Fine Homebuilding Interview: James Metoyer
  • Issue 310 - October 2022
    • Choosing a Tile-Leveling System
    • Choosing Between HRVs and ERVs
    • Custom Built-in Cabinets Made Easy
  • twitter
Taunton Network
  • Copyright
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
