I am in the process of renovating my 30-year-old bathroom. The DW wants lights in the shower area. I purchased two-recessed 4 inch Halo’s with shower trims. I’ve learned from this site that lights in a shower must be protected by a GFCI. Can I use the GFCI outlet in the bathroom? This outlet is a dedicated 20-amp circuit with 12-gauge wire. Can I run 12-gauge wire from the GFCI to a switch and then to the lights?
Thank you in advance for your input.
Sounds absolutely correct to me, but one of our resident electricians should be along shortly to confirm or deny my opinion....;-)
Another not well informed opinion here.
I believe the outlets for the bath have to be on their own dedicated circuit.
Seams like ganging a fixture would break that rule.
Anyone know what their talking about around here?
Not sure it has to be dedicated, just GFI. Some kitchen circuits ARE dedicated.
As a practical matter it meets the safety concern, assuming the light + any hairdryer load are under the circuit rating, but we'll have to wait until someone with a copy of the code comes along...
Yes, a bathroom needs a dedicated circuit for its receptacles (see caveat below). You have a choice in how you go about this. If you run only the receptacles on the bathroom's dedicated circuit, you can also feed the receptacles in another bathroom.Alternately you could wire the lights, fan, etc. on the same circuit as the receptacles (as long as it doesn't surpass the circuit's capability of course), but then you cannot use that circuit to feed anything outside that bathroom.Not an electrician. I've just had to flesh this out for my bath.'Man who say it cannot be done should not interrupt man doing it' ~ Chinese proverb
As long as that GFCI circuit you want to tap into doesn't serve anything outside the bathroom in question, yes, the NEC allows you to do that.
Thanks, all
Yes it is a dedicated circuit and it will only feed the bathroom it is in.
you could also remove the GFI recepticles and switch the whole circuit to a GFI breaker ...
Thanks Wane,
I have the outlet device already and the main panel is in the master bedroom. I like to put GFCI at the point of use.
"I�ve learned from this site that lights in a shower must be protected by a GFCI. "
That is not true.
There is nothing in the NEC that requires lights (or fans) in the area of he shower to GFCI protected.
What is requires is an appropriate rating (damp in this case) and that it be installed per manufactures instructions.
I know that some fans, when installed over a shower require GFCI protection. Have not heard of a light that does. But it might.
BTW, make sure that you main lights are not on the GFCI receptacle. You don't want a trip to kill all lights.
Lights in a bathroom (in a shower or not) are not GFI protected. Just the outlets are. Lights in a shower need the shower trim. You can either have a dedicated outlet and the lighting circuit could then be used for outside the bathroom or you have to dedicate a circuit to the bathroom.
Thanks Joe,The lights are rated for damp locations. I have read several times on this and other sites that lights in a shower area need to be on a GFCI. Better safe, and the main lights will be on another circuit.
You can put them on the GFCI in the bathroom. The way code is written, one bathroom may be entirely on one 20 amp circuit or if multiple bathrooms all the recptacles can be on the same GFCI.
Remember to use sealed lenses on the lights.
IIRC: If the fixture manufacturer's instructions require GFCI, then it is required by NEC. Otherwise, your call.
It depends. Codes can vary quite considerably from jurisdiction to jurisdiction. In my locale, the bathroom has to have a dedicated circuit, but this is the first I've heard about protecting a light with a GFCI. Here, all you need is proper clearance from the shower, and water-tight trim. Call the city or an electrician that has time to answer a few questions. Unless someone lives in your city, you won't get a definitive answer.
YES, yes and yes. I do this regularilly. The local electrical inspector is absolutely fine with it.
Have a good day
CLiffy
check your code switch controlling the lights has to be 3' from the shower also
Thanks everyone for your input,Danny
Light switch 3' form the tub? IS that a Canadian Electrical Code requirement?
Cuz it isn't in the NEC.
There is a requirement that wall switches be at least 5 ft from the inside walls of an indoor spa or hot tub. (680.43(C), 2005 NEC)
Cliff
could be canuck reg as i ran into this problem a few months ago on a job
i found i could get around it by getting a radio controlled switch from home depot and as the switch was only 6 v it dident count and got me out of the jam i was in i had to get na light in the shower after it was finished and found to be too dark inside
this remedy allowed me to avoid opening the walls up on a high end house with a nutty owner LOL.
