Wiring Question
Fenix | Posted in General Discussion on November 26, 2006 04:35am
I was replacing a GFCI outlet, and was almost done when I nicked a wire and caused a short. The existing wiring was 14/2, and there was no room for error. So I spliced in a length of 12/2 and wired in the outlet. Tested it and worked like a charm. Once I sealed up the wall it wouldn’t work. (of course). So my question is was it the spliced wire that is causing the problem ? The GFCI  that feeds this replacement is the one that keeps tripping. SO is it the wiring or something else?
    IMERC | Nov 26, 2006 04:42pm | #1
    look at the 12 to 14 connection....
    WOW!!! What a Ride!
    BillHartmann | Nov 26, 2006 05:22pm | #2
    "I was replacing a GFCI outlet,"
    "The GFCI that feeds this replacement is the one that keeps tripping."
    There is no reason that for one GFCI to feed another one.
    Or do you mean a upstream GFCI protecting a regular receptacle?
    1. Fenix | Nov 26, 2006 08:00pm | #6
      The GFCI that is upstream  is feeding a recepticle.
  3. DanH | Nov 26, 2006 05:24pm | #3
    If the GFCI is tripping it's not a bad connection, but a short of some sort, or you miswired the GFCI somehow. First guess would be that you installed it backwards.
    (I am curious as to how, in the process of replacing an outlet, you could nick a wire so badly as to cause a short.)
    People never lie so much as before an election, during a war, or after a hunt. --Otto von Bismarcki
  4. emana | Nov 26, 2006 05:55pm | #4
    If I read your post right, you did the splice and then sealed up the wall???
    That is a big no-no.
    Gunner | Nov 26, 2006 05:56pm | #5
       You didn't leave the splice laying in the wall did you?
    Pardon my fat fingers.
     http://www.hay98.com/
Tall Deck on a Sloped Lot
When deck posts exceed what the prescriptive code tables allow, it's time to consult a structural engineer for post sizing and possible bracing.
Start your subscription today and save up to 81%
