In every issue you'll find...
  • Expert insights on techniques and principles
  • Unbiased tool reviews
  • Step-by-step details to master the job
  • Field-tested advice and know-how
Subscribe Now!
Wood species for hot environments
charlemagne | Posted in Construction Techniques on March 31, 2010 09:50am
Hello everyone,
It’s my first post here, so forgive me if i use any wrong expressions.  And as a double handicap, english is not my native language.
I would like to know if there are wood species more suited for wooden houses than others in a hot and dry environment.  Or what techniques can be used to aid wood in such an evironment.
  1. oops | Mar 31, 2010 12:47pm | #1
    Are you asking about the wood you would be using for the framing of the structure or the wood you would be using as an exterior finish such as siding and trim materials?
    Just where is the hot dry climate you are talking about located?
    1. charlemagne | Apr 01, 2010 04:40am | #4
      Which place
      I'm from Belgium, but the land is located in Porutgal, http://en.wikipedia.org/wiki/Castro_Verde_Municipality
      You can see the average yearly weather a little down the page.
    2. charlemagne | Apr 01, 2010 04:44am | #6
      Wood to be used for both framing and siding.
  2. DanH | Mar 31, 2010 07:36pm | #2
    As a general rule, most woods do well in a hot, dry environment.  Moisture, either in the forrm of rain or just high humidity, promotes the breakdown of the wood, due to both chemical reactions and mold/rot.
    The other thing that damages wood, though, is sunlight.  Protecting the wood from sunlight with a good paint or opaque stain will lengthen it's life considerably.
    And, of course, in many warmer climates you must be concerned about termites.
    1. charlemagne | Apr 01, 2010 04:43am | #5
      outside finish
      I definitely want to keep the wood grain visible so paint is out of the question.  Are there oils out there that block UV ?
      1. DanH | Apr 01, 2010 07:53am | #7
        No.  Lots of claims have been made, but the best you can do is a transparent stain that has to be reapplied every 2-3 years, and even that won't prevent the wood from darkening and turning rough in the sunlight.
        Specialty semi-transparent stains such as Sikkens in the US are a little better compromise -- they slow the aging of the wood considerably more than a transparent stain and only need reapplication every 3-5 years (after the first two years).
    bambam | Mar 31, 2010 08:29pm | #3
    I live in a hot humid climate but I like cypress. Cypress is sap free so it doent bleed making it excellent to stain or paint. The tree has an oil called cypressine that acts as a preservative and is a deterent to insects too.I once worked on a house in Jasper Texas that was sitting on cypress stumps for piers. It was built around 1900.  The stumps are still there too.
  4. Clewless1 | Apr 01, 2010 08:33am | #8
    I live in the desert SW US and recently toured the Frank Lloyd Wright center in Taliesen West near Phoenix, AZ. While there, I learned that redwood was a very poor choice for a hot dry climate ... which is a little counter to my assuming that redwood was good everywhere outdoors. Apparently I was wrong. They started changing their wood to Doug Fir, I believe as the chosen wood for all their outdoor exposed conditions. Frankly I was surprised.
    Do some more research on line, though. Your choices may be more in line w/ what might be readily available in Portugal, regardless of what will be ideal.
    1. charlemagne | Apr 01, 2010 10:49am | #9
      So far most mention is about softwoods.  Are they better suited than hardwoods ?
      1. DanH | Apr 01, 2010 09:00pm | #11
        Oak is very weather-resistant, in my experience.  I suspect it's not used much for exterior applications primarily because of the cost.
      2. Clewless1 | Apr 01, 2010 09:50pm | #12
        because hardwoods tend to be very expensive. In a hot dry climate, I wouldn't tend to choose wood siding ... I'd do stucco. Either that or do all masonry construction on the exterior.
  5. gfretwell | Apr 01, 2010 11:22am | #10
    Teak is the gold standard, being used on boats for as long as it was available but "gold" is the operative word. It costs about that much money. You will still be sealing it with teak oil at least once a year if you want it to be pretty.
    IPE is a close alternative
  6. charlemagne | Apr 02, 2010 05:53am | #13
    I also like the idea of stucco, but the problem is i don't want to use any ply or osb coz of health reasons. I'm a complete noob at homebuilding, apart from reading a few books, but it's probably not possible to do stucco on a solid wood covering.
    There's 3 small houses on the property, they're tear-dows, but they will be remasoned.  But before we start to build those we want to build 3 small wooden cabins, with a fully functional kitchen, bathroom ((bath)-shower-toilet)), living-room, sleeping loft and somekind of wood burning stove for the 'cold' winter evenings.
    So far i quite like the idea of using cypress, which grows locally and is probably cheap too.  One thing i don't fancy is the seamingly high degree of maintenance but seeing they cabins will be small i might have the wrong idea about that.  All the woodwork will be done by myself, as for the rest i'll have to learn as i go.
    We wan't to keep the cabins small so people will be forced to spend more time outside, connection with nature and what not.
    1. DanH | Apr 02, 2010 07:57am | #14
      One thing to note is that what's called "cypress" in the US may not be the same stuff you have there.
    2. Clewless1 | Apr 02, 2010 09:16am | #15
      Just FYI ... I've seen stucco done w/out any sheathing if I recall correctly.
      1. oops | Apr 02, 2010 12:59pm | #16
        siding in dry climate
        You could use gypsum sheathing under stucco.  A common pratice especially before the advent of EIF systems.
        Have you considered using metal studs, joist, rafters etc.
        You could also go ADOBE as your structure with stucco as your exterior finish. It's a tried and proved method of building in hot dry climates for ages. Also has good insulation properties. I did  an adobe (mud bricks/blocks) house in Santa Fe N.M. many years ago.
The Perfect Palette for Picking Paint Colors
For your next finishing project, look no further than the Colours of London, a curated collection of 120 colors from Mylands.
  • Podcast 463: The Best of the Fine Homebuilding Podcast, Volume 3
  • Fine Homebuilding – July 2022, Issue #308
  • Pretty Good House Book Excerpt: Copper Farmhouse
  • Fine Homebuilding Issue #308 Online Highlights
Justin Fink Deck Building Course announcement
Sign Up See all newsletters
BOOKS, DVDs, & MERCH
Shop the Store
  • Pretty Good House
    Buy Now
  • 2021 Fine Homebuilding Archive
    Buy Now
  • Outdoor Projects
    Buy Now
    Buy Now
  • Shop the Store
  • Issue 308 - July 2022
    • 10 Dos and Don'ts for Electric In-Floor Heat
    • A Sturdy Rail for Outdoor Stairs
  • Issue 307 - June 2022
    • How to Raise a Post-Frame Home
    • Trimming Deck Stairs
    • Evolving an Energy-Efficient Envelope
  • Issue 306 - April/May 2022
    • Framing Stairs to an Out-of-Level Landing
    • Building a Zero-Energy Home for Less
    • Good-Looking and Long-Lasting Traditional Gutters
  • Issue 305 - Feb/March 2022
    • The Steady Surge in Residential Solar
    • The Fine Homebuilding Interview: William B. Rose
    • How Good Is Your Air Barrier?
  • Issue 304 - Dec 2021/Jan 2022
    • Why You Need Blower-Door Testing
    • Passive-House Standards for Everyone
    • Window Replacement With a Side of Rot Repair
  • twitter
Sign Up
Taunton Network
  • Copyright
  • Do not sell my information
© 2022 The Taunton Press, Inc. All rights reserved.
Shop the Store
  • Books
  • DVDs
  • Taunton Workshops
  • twitter
Start your subscription today and save up to set_percent%
